Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: Parameter Added - Driven Tire Circumference
  1. #41
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by mrGame View Post
    I am about to do a lift on my 2016 F150 Ecoboost. Is it possibility to correct tire size on it yet?
    Yes, you do it with VCM Scanner.
    Eric Brooks
    HP Tuners, LLC
  2. #42
    Dec 2010
    13
    I have a 2016 F150 and cannot correct the speedo using VCM Edditor. How is it done with VCM scanner?
  3. #43
    yes how can you do it in the scanner.
  4. #44
    Vehicle Controls, and Special Functions button in the Scanner. (If I remember right.) It's under one of the tabs.
  5. #45
    Quote Originally Posted by ElecTech View Post
    Can anyone confirm if this is true? Will disabling the VID also cause Select Shift to stop working?
    I recently did a gear/tire calibration on a 2012 F-150 5.0L by setting Used Vid to "Disable" and Use Tire Circ. and Use Final Ratio to "Enable" and the customer now complains of Select Shift no longer working.
    Running into the same problem - tire size adjustment disables Manual (shift select) mode on 2011 F-150 5.0.
    Any updates on this?
  6. #46
    Jan 2020
    3
    Quote Originally Posted by MoBoost View Post
    I also have this issue and have not found a solution yet.
  7. #47
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Could you leave VID enabled in the Calibration/Editor, and make the change in the BCM via ForScan as listed here?
    https://forscan.org/forum/viewtopic.php?t=2650
    This works on a 2015-2016 F150, lists 2011-14 as well.
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
  8. #48
    Mar 2019
    Ogden, UT
    98
    Any chance we can get an update for the 2020 Mustang GT tire size/gear ratio adjustments in the VCM Scanner?
    I've had Support Ticket #220701 in since 25May2020..
