Results 1 to 13 of 13
Thread: Misfiring like hell
    Sep 2005
    402
    Misfiring like hell
    Is there anyway to narrow it down to which cylinders are misfiring?
    I've seen other people find out which ones.
    But dont think I have that option.
    2nd ?: It says like 198 misfires but then changes. What kinda time
    frame is this misfiring going on?
    thanks
    Sep 2005
    402
    I suspect its either a bad fouled plug, or a bad ICM
    Feb 2006
    Richmond, VA
    7
    #4 is a common spot for bad plugs and burnt wires.
    i would check pending codes to see if it has P0304 listed.
    1998 3800II Camaro
    13.64 @ 98 cam only, stock tune
    richmondperformancemusclecars
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    Are these at idle, or while driving?
    If it's at idle and you're cammed, then you'll never get rid of those misfires. When scanning individual cylinders, i get close to 400 misfires per....
    All Motor 2001 GA GT1
    Sep 2005
    402
    it is all the time, idle or driving. driving me crazy, plus i need to recalibrate my maf so my afr isnt Continually 18.0+++++++ afr
    I dont have an aftermarket cam yet
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    if you are misfiring and you are way lean..try getting fueling back inline first..even just adding 10-20% to the entire MAF table to get it closer would be good...
    then do a plug change as teh stockers(which they claim are good to 100,000miles cause they are irridium)are really only good til; 20,000 or 30,000 max..teh irridium tips are gone within 10,000 miles..especially if you hammer on it.
    get some good NTK copper plugs and change them every 2-3 oil changes or every 8,000-10,000 miles in general
    this will most likely fix your misfires...
    all vehicles can benefit from a regular spark plug change
    -Scott -
    Sep 2005
    402
    anyone know what cylinder p0300 is? i know it isnt cylinder 3, cause that'd be p0303
    thanks dude
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    P0300 = General Misfire
    Always Support Our Troops!
    Sep 2005
    402
    is there an easy way to multiply by 15%? Im just retarded and dont know the formula, so I have to manually put it in.
    Apr 2003
    Almost 2000 feet.
    7,876
    Select the whole MAF table. Put 1.15 into the box at the top. Press the X button. Done
    Sep 2005
    402
    thanks, adding 15% really helped me get back inline.
    on startup (cold) it seems rich (13s)
    i'd like to add more to it, during closed loop which it gets back into the 17s,18s, 19s....
    Dec 2007
    Montreal, Quebec, Canada
    339
    Bad move to keep tuning with a known hardware issue. Misfires are 100% strong indications of hardware issues. It can be:
    - a bad plug
    - a bad wire
    - a bad coil
    - a bad ignition control module
    - a bad injector
    - chunked piston
    - valve issues
    What have you done to make sure it is none of the above before trying to resolve a hardware issue by tuning?
    Rule #1 of tuning is that you never, EVER compensate in a tune for a mechnical or hardware problem.
    You want to know what cylinder is misfiring? Add the PID for cylinder misfires for all 6 cylinders and scan!
    '99 Black GTP Sedan
    3.4-2.6" PB Quick Change pulleys, Custom CAI, XP Cam, N* TB, LQ4 MAF, SLP headers, 42.5# Injectors, 180/195* thermostat.
    13.501 @ 103.392 on 91 (2.4 60-foot).
    13.82 @ 105.28 on 87 octane! (2.42 60-foot).
    263kph top end as shown on the GPS.
    All this and 39MPG to boot. What more can a man ask for?
    * Just another enthusiastic amateur tuner! *
    28,285
    This thread is from Feb 2006, I can only assume he's fixed his missfires since then...
