Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 114
Thread: 5.3 first attemp at a tune may need some adult supervision
    Tuner Redtruck1's Avatar
    Oct 2014
    Atlanta
    61
    I have taken my 4.3 out of my 2001 Silverado and replaced it with a 5.3 whitch I added a GM stage 2 cam. I used a factory flash for a 2002 that has all the same equipment to get the truck running. I am having an issue with rough idle P0106 and p0121 codes, off idle and WOT seen to be good but still have a raw fuel smell whitch I am thinking my be fixed with injector timing.
    cam specs
    intake duration 227
    exhaust duration 239
    lobe separation 108
    degrees overlap 17
    lift 551
    Is any help avalible
    Advanced Tuner Cyrperformance's Avatar
    Apr 2014
    Haines City, Florida
    325
    Are you running cats or deleted?
    2006 Escalade LMM Duramax Tuned
    2000 S10 Twin Turbo 6.0L
    56 GMC 100 Status Unknown
    Oct 2014
    Atlanta
    61
    All stock Cats o2s fuel pump intake just like factory.
    Apr 2014
    325
    Are you running a wideband gauge? And did you try some compares to any files in the repository?
    Oct 2014
    Atlanta
    61
    No wide band and wanted to try to get this tune I feel I am close, did not want to try another persons tune until understanding better.
    Apr 2014
    325
    Without a wideband it will probably be a little difficult, compare injector settings and pull a little 5-10% from idle area and see if that makes a difference.
    Oct 2014
    Atlanta
    61
    Cool I will give that a try thanks for the info.
    Apr 2014
    325
    Are you running the MAF?
    Oct 2014
    Atlanta
    61
    yes sir
    Apr 2014
    325
    If you calibrate the MAF then it should solve most of the issues if the injector data is correct.
    Oct 2014
    Atlanta
    61
    Do I use the Histogram method for calibration or is their a simple equation to figure out the calibration.
    Apr 2014
    325
    Look through the sticky' sand you will find it I believe posted from William Henn, a complete guide for MAF, VE etc. or order the Banish DVD which is pretty good for basic stock configuration tuning and larger cams. Summit sells it and some members sell them used a little cheaper some times.
    Apr 2014
    325
    Oct 2014
    Atlanta
    61
    Thanks looks simple even for me.
    Apr 2014
    325
    Just make sure your steady with the throttle and try not to let off. Find a long long stretch of road that is pretty empty. Run the scanner a couple times logging to get the feel for how it works. Just remember when you run up the scale hit stop scanning before you let off the throttle. Save the log before you shut the engine off then copy and paste special multiply % appropriately. I paste once then run log again and paste half. Then log again. The MAF is pretty simple.
    Oct 2014
    Atlanta
    61
    This may sound trivial but I am not having any luck adding MAF-STFT to the histogram list any sugestions
    Aug 2006
    5BA8
    3,220
    Quote Originally Posted by Redtruck1 View Post
    Make sure you have MAF Hz and STFT % bank 1 and 2 in your primary PID table. If you do not have them selected, the histogram will not come up.
    Also, if you're trying to dial in a MAF or VE table using STFTs, make sure your LTFTs are disabled and zeroed.
    EFI specialist
    email=[email protected]
    Oct 2014
    Atlanta
    61
    That's the ticket idles better but still have fuel smell out tail pipe. will take some time need a partner to control the laptop thinking the raw fuel smell will go the closer I get to 1.00.
    Apr 2014
    325
    Whenever you are using the scanner you have to have the PID's in the table to be able to use it in a histogram. Very important step when trying to log certain items. Glad to hear you are getting the hang of it. READ READ READ
    Oct 2014
    Atlanta
    61
    Now that I have this histogram thing figured out I have noticed a problem the vehicle will not down shift or fast accelerate from time to time very random. it has a code for tps performance but it is not current says passed you think the TPS is failing causing the shifting problem?
