Originally Posted by
Flyer
Spawne, I did. Define odd, lets work through the logic and see how odd my thinking is. Which ones are you referring to.
Cruze, I thought that too, but it doesn't make since to me. I thought maybe it's a glitch since it's happening right there where it starts to richen up. I added the .001 to the 2.500 in an effort to clear a glitch, but no dice. Following the PE table, it should start out and richen itself up.
I changed the PE table because at heavy throttle, I'd see really lean conditions down low (1.066) and it would start adding fuel and clear up the knock and run better.
