Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 110
Thread: How to perform a segment swap using the segment swapper utility
    This will also work on a HPT custom OS as long as the "from" segment file matches the original OS. Just did it.
    Bo Woody owner:
    APS Automotive
    www.apstuning.com
    Oklahoma City, Oklahoma
    405-424-RACE
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by caesar View Post
    That is done for a reason. You can only swap a segment from the same OS, otherwise you will either brick your PCM in most cases or cause the OS to read incorrect values.
    I know this I was just commenting to make it known that is the reason...
    Located in Central Kentucky
    ShorTuning
    Jan 2013
    42
    I'm trying to swap a 6.0l 4l80e to a 6.0l 4L60E, Same OS same year, using a 5.3l 4L60 program for the trans segment. When I look at the DTC's they don't transfer over even when I select the trans segment and the DTC and copy them over in the segment swap tool. The shift sol. the trans fluid, and the TCC, and other codes don't have the check box marked and it says No MIL Light? Am I doing something wrong or will everything work?
    Dec 2010
    Richmond, VA
    40
    I tried playing with this segment swapper tonight with a couple files. I can perform the segment swap, but when I go to close the segment swap window the vcm editor software crashes. Any ideas?
    SHUETUNING
    Powertraincontrolsolutions
    Dec 2010
    Richmond, VA
    40
    Nevermind. It had to be a licensed file.
  6. #26
    Feb 2015
    Spring Hill, Florida
    5
    thanks for sharing!
    2001 RCSB Silverado 2wd, 5.3/4L60e, 3:73, all stock besides cold air intake and true dual exhaust w/ cats
    ~LQ4/4L80e swap in progress~
  7. #27
    Mar 2015
    4
    Will I need to get hold of an ECU to copy from or are there files I can download?
    Will a 4L80E segment work for the 4L85e?
  8. #28
    SoCal
    21
    Ive never done a segment swap before and would appreciate any help, where do I go to get a file to segment swap from? I am converting an 03 Silverado from a 4L60 to a 4L80. 12579405 OS
    Full Throttle Kustomz llc
    "For Those Who Live Life at REDLINE"
  9. #29
    SoCal
    21
    Found one
  10. #30
    Question, how long does it take to hear back from HPT when you email them requesting 2.25 beta?
    77 C10 - 416 6L90e Swap
  11. #31
    16
    I just downloaded the 2.25BETA and cant find the the segment swapper!!??
  12. #32
    16
    Found it, Does it only light up as clickable when you are able to swap? And do you need a license on the compare file?
  13. #33
    Oct 2015
    30
    opened over 100 files from the tune repository looking for a matching OS. not having any luck at all. hope I didn't waste 2 credits on pcm that I cant use for a segment swap. need a 4l80e segment.
    my OS ID= 12606960
    would really appreciate the help I'm totally lost
  14. #34
    Tuner hivoltagedriver's Avatar
    Apr 2013
    Oklahoma
    50
    I have the same OS ID. 12606960, and can't find a 4L80 file with the same OS to do the segment swap from. Help!!
    2017 JKU Rubicon: Purple, long arms, tons, 40s, Banks CAI, Borla cat-back, TD2/HPT tuned, daily.
    2017 GMC Sierra SLT: 6.2/ 8spd. Just getting started on it...
  15. #35
    Quote Originally Posted by hivoltagedriver View Post
    What is the application?
    Bo Woody owner:
    APS Automotive
    www.apstuning.com
    405-424-RACE
  16. #36
    Quote Originally Posted by mecanicman View Post
    12606960 is a 2005 flexfuel o/s. There is no 4l80 segment that hpt can swap for you. Post up your STOCK file read out with 2.24 and I may be able to help.
    I will also help you if you host up your stock file. Or if you want to send me your PCM I can convert it for you but you will more than likely have to license it again depending on what I have to do to make it work.
    Bo Woody owner:
    APS Automotive
    www.apstuning.com
    405-424-RACE
  17. #37
    Sep 2013
    427
    when doing a segment swap do you need to license the compare file to do the swap to the file that is receiving it or you don't need to Cheers Bret@ultimatelsxtuning
  18. #38
    Sep 2013
    427
    with the T42 Tcm , is it true you can't do a segment swap etc 4L80E Into E38 PCM...
  19. #39
    Jul 2012
    Florida
    1,462
    Quote Originally Posted by ultimate lsx tuning View Post
    That's what I have heard. I'm using the 4L60 tune to run the 80. You can do it with two relays or switch a couple of wires in the trans plug. I will look for the diagram and post it. PCM of NC sells the relay harness if you don't want to switch the wires.
    2013 Silverado 5.3, 6L80k 8.8
  20. #40
    Feb 2006
    South Carolina
    1,525
    The TCM is not linked to the license of the VCM, so you can put in a new TCM and re-read the file, or TCM flash only (Write Entire) with the new OS.
    Jaime
