.... that I have located the 7,000 RPM limit that puts the car into failsafe.
If you have a Falcon with a 5.0L and this issue, post up your file, I'll manually make the change, and we can test it.
Eric Brooks
HP Tuners, LLC
Nice one eric as this was a typical issue with the fast snappy 1-2 change throwing the car into limp mode
FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
SUBARU BRZ ......AVO TURBO KIT coming......soon
VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
I see the sct camp had it sussed a while back but good to know where the issue is
Keen to see they outcome of this Eric, My car will bang the limiter on a 1/2 shift so it's not just 5.0's that have the issue.
04 Velocity MKII M6 & 06 BF F6 555 ZF6
Email sent to your address Eric.
Any updates on this?
Hi Eric, Have you had any luck with the above issue. I'm still yet to check codes on mine, but experienced something similar on a 2-3rd shift last night with some spirited driving.
There is few guys having issues with Big Converters in the ZF eric, there appears there is a max slip table, or max input vs OSS table we don't have access too, It appears the converters won't lockup and mph is way down at the track. Are you able to see if there is anything in there that could prevent the converter from locking up.
Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
The code I've got was P0701- No MIL- Occured on 2-3rd gearshift (might have just kissed the limiter as tacho and driver is a bit slow ) Car went into Limp mode, "D" flashes on the dash. Had no auto kick down etc in limp mode. Thought I'd finally snapped my cryod input shaft but still had drive. Coasted around into a car park, shut the car down, fired it back up and all was good again. This is the first time I have experience it- but it sounds similar to the issue the other guys are getting.
Just wanted to pass on my thanks to Eric for sticking with this, not a huge deal for the T6 owners out there but us V8 guys need the rpm badly if nothing more than not stuffing up runs at the track trying to extract the last bit of performance. I have data logged a heap of 2-3 shifts past 7000 rpm and also some 1-2 shifts which exceeded both rpm/sec rates and the 7000rpm limit and no trans faults at all.
Here's a quick vid taken
http://youtu.be/poamZt-cWrw
The rpm change rate "trans fault" affects almost everyone with wheelslip on gearshift so I am sure you can take advantage of these finds Eric has made.
Daniel
what needs to be adjusted to fix it?
Thanks for your help
Mark H.
thank you.
Mark H.
