Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 163
Thread: MAP sensor question
    Jan 2014
    Melbourne
    133
    MAP sensor question
    Hi guys,
    I have been having a couple of issues with my map sensor dropping out at 24psi.
    Can anyone confirm that you can go higher then that on the standard map sensor.
    As far as I am aware that the standard sensor is an absolute 250kpa sensor.
    Has anyone moved up to a 3 bar sensor to run higher boost?(Is it even possible?)
    Thanks guys
    Feb 2010
    Perth Australia
    480
    You can go higher, but you will have maxed the sensor. Once you have maxed the sensor the car will not be able to to read the increased load so you'll need to turn accordingly. TMap calibration is the holy grail. HPT doesn't have it (Eric was working on it a while back) SCT doesn't have it either. One private tuner (who apparently developed his own tuning software has stated he has it mapped.
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    Sexface4lyf
    As plumpkin said, it will peg and then your flying blind but many have done it so get ya dice rolling hand ready and throw into the wind
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by hiddeous View Post
    I have to wait until 2.25 is released before I can add them.
    Eric Brooks
    HP Tuners, LLC
    Jan 2014
    Melbourne
    133
    Eric,
    How far away is 2.25??
    Really want to put a 3 bar sensor in it.
    No pressure...
    I have got my territory down to less then 3% long terms until I go over the 255kpa.
    Long terms hit 15 to 20% once over the threshold.
    Feb 2013
    519
    Needs more piks of this 24+psi terri asap !
    Jan 2014
    Melbourne
    133
    Quote Originally Posted by JETURBO View Post
    Lol... I looks like a standard Ego territory turbo.
    Has a few mods including built engine.
    Feb 2013
    519
    Run the tank down the 1/4 yet ?
    Jan 2014
    Melbourne
    133
    We are looking at running on the 7th
    It will be a long time down the 1/4 compared to your car
    Feb 2013
    519
    @24psi u should get damm close
    Jan 2014
    Melbourne
    133
    Hopefully it gets a fair time.
    I know that the gearbox is up for a rebuild but I will run it anyways.
    I want to sort out the 4th gear change before I head to the track.
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by bugsy View Post
    bugsy, excuse my ignorance but what do you mean by this?
    From my old logs my STFT hit 26% around 200kpa but that is the desired lambda that Fords put into the STFT when running out of closed loop (1-.26 = 0.74 which is the lambda I have set for up high to compensate for the LPG injector fall off in flow up top). The LTFT were 0 once out of closed loop.
    Aug 2012
    Melbourne Australia
    344
    With 24psi you should have a real chance of knocking off TOOOGO's Territory time of "11.2@122 mph with a 1.66 60 ft" which he ran with 404awkw and 19psi (factory turbo). So as Jet says "u should get damm close".
    Way to go bugsy, good luck and when are you running it?
    Jan 2014
    Melbourne
    133
    Hey Darryl
    I had been playing with the open loop tps threshold.
    One of the logs that I had done show the Map sensor hitting 255kpa then dropping out then.
    LTFT went high.
    I will set up it again and try to do it again.
    Hoping to run it this week end coming Darryl.
    Just got to work out what I changed to get it to stall up to 3000rpm with out turning the tires.(Brakes and hand brake don't hold it)
    Feb 2013
    519
    The secret lies in x4 M/T's at 275wide ea
    As iirc thats what the silver beast had to do to get moving
    Oct 2011
    QLD, Australia
    436
    If hasn't had a built trans previously and it isn't shifting 3-4th at WOT you might be trying to tune around a mechanical issue Biugsy
    Sep 2013
    Sydney
    123
    Hey Eric, have you allocated any time to work on re-scaling the t-map sensor? I'm throwing some more boost at my car in the next couple of weeks and at 3-4 bar sensor would come in handy?
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Peppy_t View Post
    I can't add the parameters until 2.25 becomes the stable release and 2.24 goes away.
    If you want to send me the file, I would gladly change it manually
    Jan 2014
    Melbourne
    133
    Eric,
    Would you be able to add the change to my file as well?
    Oct 2007
    Crawfordville, FL
    2,412
    Eric,
    I can change it, but will need to know the slope and offset of the new sensor.
    Eric Brooks
    HP Tuners, LLC
