Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 163
Thread: MAP sensor question
  1. #41
    Aug 2012
    Melbourne Australia
    344
    And for a 3 bar t-MAP from the site Jamie referenced above we have:
    We are awaiting final specification data from Bosch on this particular item but customer information indicates the following calibration with linearity between points:
    P1 -> 11 kPa at 0.25V
    P2 -> 307 kPa at 4.75V
    P = V * 65.77778 - 5.444444 (Kpa) === V * 19.4241 - 1.6077 (inHg)
    And Bosch implies
    P1 -> 20 Kpa @ 0.5V
    P2 -> 300Kpa @ 4.5V
    which would give:
    P = V * 70 - 15 (Kpa) === V * 20.671 - 4.4295 (inHg)
    So what do you guys think as I am looking for the 3 bar map as my car also idles at the bottom of the range.
  2. #42
    Jul 2009
    326
    Guys have used 4 bar sensors on the stock PCM without issue.
  3. #43
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by IH8TOADS View Post
    Do you know what they are using to reprogram the PCM to the new MAP sensor?
  4. #44
    Oct 2011
    QLD, Australia
    436
    The guy I know of, was his own software.
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
  5. #45
    Jan 2014
    Melbourne
    133
    45T-XR,
    Is that Danny your thinking of?
  6. #46
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by bugsy View Post
    45T-XR,
    I think that's who he is referring to. Danny told me he had figured it out too.
  7. #47
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    Sexface had the zf calibration worked out over two years ago but like that he has shared nil
    And I don't blame him either to be honest
    He's one smart cookie
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
  8. #48
    Jul 2009
    326
    Yeah Danny put a 4 bar on his and it's working well he said. That was a long time ago now though. I'm not sure if he can flash the TCM Jet.
  9. #49
    Oct 2011
    QLD, Australia
    436
    Correct!, There was actually a good write up on fordxr6turbo.com from memory. Was years ago that I read it. Danny has HP too now and I believe he has helped Eric out with a bit of stuff also.
  10. #50
    Jul 2009
    326
    Yeah sweet
  11. #51
    Oct 2007
    Crawfordville, FL
    2,409
    Just sent a file to someone to test out. Will post results soon :-)
    Eric Brooks
    HP Tuners, LLC
  12. #52
    Feb 2010
    Perth Australia
    480
    Geez Eric, I've been pushing for this from day dot. Where's my test file?
  13. #53
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by hiddeous View Post
    Shoot me an email with your file, and the slope/offset for the MAP sensor you are switching to.
    Eric Brooks
    HP Tuners, LLC
  14. #54
    Aug 2012
    Melbourne Australia
    344
    Took a while to find it but yes the car does "idle" with the 4 bar map sensor at 44Kpa and about 1200rpm. Danny (AKA headsex) also provided a video which gives enough information for work out slope and offset. See:
    http://www.fordxr6turbo.com/forum/to.../#entry1021952
    A mate has/had his car tuned by Danny and he reported that Danny could do the zf as well and it was at a very reasonable price (about 1/2 what other people charge).
    Another staggering effort by Eric
    Very interested in outcome.
  15. #55
    Jul 2009
    326
    Yeah my bad, Danny is all over it!!
  16. #56
    Aug 2012
    Melbourne Australia
    344
    Toads, actually my bad as the cold start was around 1150rpm and later it was sitting at a map of about 40kpa when idling at 750rpm. Sorry about that.
    Like bugsy my car idles in gear at about 700RPM and 25Kpa.
  17. #57
    Jul 2009
    326
    I was referring to Danny and the ZF tuning. Just log the MAP before and after the t-MAP change to make sure the same idle MAP is being recorded. Danny said he's changed the boost sensor also, without it the pegged boost sensor freaked out apparently.
  18. #58
    Jan 2014
    Melbourne
    133
    Boost pressure sensor that would be needed to match the 4 Bar T-Map is under BOSCH 0261230046
    You would peg the T-map before pegging this.
  19. #59
    Aug 2012
    Melbourne Australia
    344
    I guess Toads is implying that Danny has found you can't just disable the Boost sensor unless someone (Eric?) knows a way around this.
    With respect to the 4 bar t-MAP sensor, then from Danny's video he gives us:
    100Kpa = 1.089V
    45Kpa ~= 0.493V which is suspiciously close to 0.5 and 50Kpa which is what he claims the Bosch doco says.
    So it is a trivial task to work out the Slope and Offset from his video. This would also give us an idea if the numbers we have given Eric are on the correct path. Thank you Danny
  20. #60
    Jul 2009
    326
    Nah just run open loop
    And disable the boost sensor. Should work like a charm.
