Not upset at all, I was just surprised that he did what he has already complained about Jet doing this and then pleading ignorance.
As I have stated many times earlier I have him on a high pedestal and he has been very helpful.
As can be worked out from post 87 he was not onto it until I PMed him the info. Maybe he has been down this path before and it did not click until I PMed him and so did not realise I sent him the info. If so then I misinterpreted that he had used the info I sent him.
The post he put up was interesting but not the same IIRC. Maybe some went on to do this, Rob82 looks like he did it with the 3 bar t-MAP which is perfect for this and the 4 bar is not too bad.
What this gives is tuning up to about 410kpa. As I have emailed toads, boost is manageable from about 10psi to 45psi and all load, AFRs , ... are what the tuner expects. Low Boost, DFCO (although bugsy is making progress) and false MAP readings on the scanner are the issues but we have everything under control in normal driving and when boost goes from 22+ to over 32psi. At least you can vary the boost above 255KpA and not have to fudge the tune in the hope that the injectors, spark, ... will be OK.
I was hoping that someone would work it out and was happy to write it up and explain how and why the negative numbers are not an issue (ie how to work around them and still keep the tune as good as the factory SD). I went down this path and found the slightly negative numbers with bugsy's sensors and then thought about what they meant and guess what they can be worked around, in fact most of them occur where we cannot get to and the others at high map and are easily compensated for.
