Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: timing and fuel cut between shifts?
    Sep 2008
    399
    Can you guys give me some pointers on my 2014 silverado 5.3? I have a lot of the tune done, but I'm still getting timing and fuel cut between shifts. Not nearly as bad as stock, but it's still there
    Sep 2008
    399
    Immediate eng trq src goes to trans S during the shift.
    Aug 2009
    Calibrating
    3,373
    Trans Is doing it
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Sep 2008
    399
    yes, ive logged eng trq src and see thats its trans s, but for the life of me i cant find the table causing it.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by SilverBullet6.0 View Post
    Try Trans>Torque Management>Shift Torque factor....change all 1.0 to 0.5 watch for the changes in shift tm by shift sequence, adjust each accordingly. Reducing the value should reduce the amount of TM. You can then leave the Torque reduction features enabled above.
    Ed M
    [email protected]
    Sep 2008
    399
    That helped quite abit on the feel. A tad harsh now, but i can back pressures back down. Now, how do I get the throttle to not he so laggy? It does fine if I'm already on the throttle and just increase it, very responsive. But going from 0 throttle, there is a horrible delay.
    Mar 2007
    Florida
    3,773
    A log would help as well as a copy of the tune.....
    Ed M
    [email protected]
    Sep 2008
    399
    I'll post both when I get home tonight. Out with the fiance right now.
    Sep 2008
    399
    What would you like to see in the log?
    Mar 2007
    Florida
    3,773
    Standards including WB (if available), VSS, RPM, Advance, Throttle position, ETC Desired Position, Absolute TPS, Delivered Engine Torque, Trans TqMgmt Type, time of latest shift for starters.
    Ed M
    [email protected]
    Sep 2008
    399
    I'll set up a cfg file for all that and get some logs...
    Sep 2008
    399
    Any of that specifically in chart or histogram? Or just table?
    Mar 2007
    Florida
    3,773
    Table and of course chart to be able to see the PID's. Histo's can set up as needed.
    Ed M
    [email protected]
    Sep 2008
    399
    Here is a short log showing how my throttle "ramps up"" instead of jumping to full throttle when i smash the gas. also shows the shifts, still getting fuel and timing cut with the changes you suggested. With the shift factor at .500 and shift times at 75% of stock, its firm, but still cuts fuel and spark. I tried -0.5 factor and it was way too firm. put shift times back to stock and it was still firmer than Id like. Shift pressure was set back to stock as well. I want to get the cuts lined out and torque management, then ill play with shift times and pressures to make the shifts feel good. Anyways, heres the log and accompanying tune.
    14 silverado mod jeremy.hpt2014 silverado throttle lag and shift cut.hpl
    Mar 2014
    McAllen,TX
    160
    its super easy its just trial and error good luck on the tuning
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Sep 2008
    399
    Josh, care to elaborate? I've tried damn near everything
    Sep 2008
    399
    Shift torque factor, adder, up shift limit, axle limits, trans limits, driver demand tables. I've changed them all and made progress to a point, and then it falls off. What am I missing on these new trucks?
    Sep 2008
    399
    This is the current tune in it. Shifts feel better (firmer and quicker), but looking at a log and the fuel/spark cut is still there and lasts for the same ~0.2secs.
    Sep 2008
    399
    I turned the master disable ofd and it still occurs, immediate eng trq source still says trans s
    Mar 2014
    McAllen,TX
    160
    those that you mentioned have nothing to do with that delay you have to go more in depth into the transmission pm me
