After installing the current version, suddenly I have all sorts of scanner bugs.
Specifically the cylinder air mass shows no y axis values or units, the table no longer displays any units for some of the right side values, the MAF says its logging voltage, when its actually logging Hz.
If I go into the setup for the histogram, I can select the timing table again, and it populates the table setup with axis values, however, it will not apply them no matter what.
If I open the default config files, they appear identical to this one, without axis values or labels etc.
I tried to do a repair install, no change.
