Thread: Commanded Lambda PID
    Oct 2009
    321
    Lets see if I can make what I'm looking for make sense.
    With the scanner, I am reading my NGK AFX in Lambda. I have made a "Commanded Lambda" PID that is essentally Commanded AFR/Stoich AFR. It works well when I am using a fuel with a known Stoich AFR.
    The issue that I ran into yesterday was when I was doing a Flex Fuel tune on a CTS-V. When the Stoich AFR changes based on the fuel composition that is currently in the car, it obviously skews my Commanded Lambda PID.
    Is there a trick to making a PID that will take fuel composition into account?
    I realize that sometimes it's easier to just do the math, but I've gotten spoiled with my histograms doing everything for me.
    Jul 2013
    Streets
    I believe the only way to do that without switching tunes, would be with an ethanol content sensor and a factory pcm/calibration from a flex fuel equipped vehicle. If you're not referring to ethanol based fuels, I think it would be near impossible to implicate a feature like this based on fuel octane and/or oxygen content. A lot of stand alone EMS have this feature for ethanol content and blending that are user defined, however work pretty much like a factory flex fuel system.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Use Commanded EQ Ratio. You'll find that it's actually commanded lambda.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Oct 2009
    321
    Perfect. Thanks Dave.
