Ford racing crate motor NO VIN on HPtuners 3.2 OS What Hardware should be selected?
There are a few different kinds. Up to 15 Coyote is Copperhead, Ecoboost is TC-1797 and 15+ Coyote is TC-1791.
Have to ask y you guys don't add the description to the read program as to what each ECM will read? But anyways I have a 2009 f350 with the v10 gas engine and have tried all listed above with a checksum error after most of the reads not use to selecting the ECM type 2.24 always did the work. So my question is witch one most I select have emailed hptuners with an info log but still no replie plz help
PCMs are used in so many different applications, so that makes your suggestion hard to implement. The software doesn't ask you what the PCM type is if it is a OS that we already support. If you selected something, it read out and you got a checksum error, that means that either it is a non-stock file (already tuned) or it is a definition we haven't added support for yet. Email that .hpt file in, and we will get it added.
Regards,
Eric
Eric Brooks
HP Tuners, LLC
I have sent in four different read files to hptuners not sure if there read with the proper hardware but sent all four reads there All different hardware selections and in a bit I'm going to go try the other hardware selection such as the one that says its for the f150 never tried any of them
Not sure I have emailed hptuners an info log and the four files I pulled my email is [email protected] were do I get the osid as the computer has no sticker anymore? Would prefer to talk threw email so we're not putting useless info on the form. Thx tyson
both of the 2014 flex and 2015 taurus not support ??
Any Update for those cars ??
I am trying to read a 2003 Harley Davidson edition F150, every time i get this? no options under either menu to select...Capture.PNG
Gf just got a 2014 Ford Edge. Is that supported? Non eco boost.
Guess it's about time I play around with Ford's way of doing things if so
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
ESYS it was.. in case anyone is reading in the future
2012 F-150 5.0 I've tried every one and all of them are failing.
