Results 1 to 19 of 19
Thread: 2012 Challenger (how to disable TCS on dyno)
    I heard the Diablo has some sort of "dyno mode" in their software, anyone know how to get the tcs to fully disable?
    h
    13,571
    Pull the ABS fuse??
    Works on some GM vehicle.
    Otherwise I have no clue, but thats just an idea.
    I did that but then it wouldn't shift lol
    Feb 2006
    South Carolina
    1,525
    You'll have to go through and disable the ESP switches in the calibration yourself. I've read that the "Dyno Mode" Diablo uses is them actually using the engine displacement bit to cause the whole system to "fail," but I can't say for sure.
    Jaime
    Dec 2014
    26
    If you need it for the dyno, just press the ESP button for about 10 seconds and it will be fine.
    That only works on SRT's I believe.
    Dec 2014
    26
    Works on all, just had a 2013 5.7 on the dyno today
    Tuner Ls3sierra406's Avatar
    Jul 2011
    Texas
    51
    On diagnostics torque corralation try setting all torque & rpm= (1933) & torque delta default=(1933) Engine friction torque last (4 parameters 0.00 out= RPM over 5,000rpm & Torque over 55.0) I might be wrong but I'm in the same boat still learning if I'm wrong please anyone feel free to correct me.
    Dec 2014
    9
    Holding the esp button down for 10 sec works fine on my 14 rt.
    If you have a factory scan tool, you have to enable "emissions rolls test mode." Or you could take apart the console and unplug the "G" sensor.
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    We just recently added the Displacement parameter of which, if you set to zero will disable TCC/ESP. It should be available in all capable calibrations in the latest beta.
    Mark
    Nov 2014
    48
    Very niceeee... thanks mark good work guys.! Just in time.
    Mar 2012
    19
    Thanks Mark. My way to TCS-OFF is turn Brake line-lock on.
    Mar 2015
    24
    On an RT 09 challenger to turn it off, Get mph up to say 10mph and take key and turn it like you were going to start the car and hold it there.
    It will chime and show disabled on the dash. As far as the push button start, remove button and use key fob to like above.
    It will not engauge the starter. You must be rolling on the drums or moving down the road, aprox 10mph.
    Yes, mine also on the line lock. Untill next key cycle.
    FlatTop
    Dec 2014
    9
    Mark Will disabling it through displacement cause any idiot lights? Id love to just leave it off!
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by justin14 View Post
    I haven't tested it myself in person, so I haven't seen the exact lights that come on but I imagine you will for sure get the "TCC/ESP off" light that will stay on for good. Give it shot, if your dashboard lights up too much for your taste afterwards just replace the stock value back in the variable and re-flash.
    Dec 2014
    9
    Sounds good, my 14 rt with a 392 swap and cam gets tuned very soon. I'll be sure to post the results
    Dec 2014
    9
    I just tested zeroing this value out. Works like a charm. It does however turn on the esp and abs light
