Self inflicted:
On my Desk top the VCM Scanner under the histogram works fine when you click 1, 2, 3, 4, up to 9
on the my Labtop only 1 and 2 works on the histogram
when you click on say histogram 3 the message lists ( This histogram is not supported with the current loaded parameters,
and when I go to add the parameters, the original parameters are not in the histogram configuration,
I went to the Row & Col Axis and on the drop down they are in my desktop but gone in my labtop,
Pretty sure this happened the first time I used it on my personal truck and was trying to save a log file,
Now when you look at the file name for the scanner it reads what I thought I save the truck log as
so now when I open up the scanner it says VCM Scanner - config (default Imperial.cfg) - Chevy Silverado (V8)
so when I was runner a scan and tried to save the scan it wiped out the histogram setup 3-9
I tried to remove the program from my labtop and re-load the software but the same scanner with all the saved files are still there,
worst case I will have to purchase another labtop but that seem extreme,
any help would be great,
