Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 90
Thread: Chrysler/Dodge/Jeep/RAM PCM Identification - VCM Suite 3.0+
  1. #41
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by hellbents10 View Post
    Its a NGC4 controller in a 2010 Jeep that originally had a V6. The vin is the V6 but the operating system is the NGC4 V8.
    So what is the software identifying the PCM as? a NGC4? and then what should it be?
    Also, what is the operating system (OSID) so I can correct this if needed?
    NOTE: just because it was a V6 and it is now a V8, doesn't mean that the PCM type changed. NGC4 was used with both of those engine types in 2010. If you are still using an NGC4 with the V8 and it is identifying as an NGC4 then it is okay and you can go ahead and read it.
  2. #42
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    605
    Is write support available for 2005 Dodge Ram 1500 5.7 V8? I don't want to order Dodge credits if I can't use them?
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
  3. #43
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by Billf6531 View Post
    It's an NGC3, so yes. There's a list here that I keep pretty well up to date on supported vehicles: Supported Vehicle Thread
  4. #44
    What about support for 03 4.7l durango thats NGC.
  5. #45
    Advanced Tuner caesar's Avatar
    May 2003
    227
    Quote Originally Posted by JoshCP527 View Post
    This is an NGC1. It is not currently supported.
  6. #46
    Dec 2014
    Ontario
    22
    2012 SRT8 charger so far NO issues reading the PCM and scanner is looking good also havent had much chance to dig in yet but all seems good
    D
  7. #47
    Nov 2014
    25
    So how would a guy go about getting the newest beta? I've been wanting to experiment on the ol lady's 2014 ram hemi
  8. #48
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by 07TurboTruck View Post
    send an email to support requesting access to the beta. Include your MPVI serial number in the email so Support knows where to post the download link.
  9. #49
    Tuning Addict
    6,797
    Alright, I know HP just got the Hellcat sorted out. Just wondering if it's truly 100% supported now and if I can tune a 15 hellcat with a manual trans cause the shop will have one first thing Monday morning.
    Am I going to need to send in the ecm for unlocking?
    Finally what do I need to know or use configuration wise to read the ECM?
    Thanks,
    Greg
    ~Greg Huggins~
  10. #50
    May 2003
    227
    Thanks,
    Greg
    Yes, you need to send in the ECM for unlocking. There is a post stickied in this forum with instructions for 2015 vehicles.
    Otherwise you will have no issues tuning the manual.
  11. #51
    Tuning Addict
    6,797
    Yes, I should have posted a follow up. I read that afterwords. Amazing how the OE's are going way out of their ways to try and keep us out of doing anything. BUT I think it's an entire waste of "their" money because there will always be people, hackers, whatever out there to work around this kind of stuff... Just makes things a bigger pain is all unfortunately.
    Thanks for the reply.
    ~Greg Huggins~
  12. #52
    May 2015
    1,908
    NGC3 CAN - in the Spark>Advance there is a an Idle Spark for Drive and P/N but looks undefined. Has one row, horizontal is * F (one value of -83.2) and column is spark. Is this a table used in the PCM? I noticed on NGC4 and up this isn't even visible in the Spark tabs.
  13. #53
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by 06300CSRT8 View Post
    Those are not active. The primary idle timing tables are the PT Base spark and the Idle Torque Spark and Throttle tables.
    Jaime
  14. #54
    May 2015
    1,908
    Awesome thanks.
  15. #55
    May 2015
    1,908
    Same PCM (NGC3 CAN) the Idle>RPM Idle Runtime Based all the adder tables looked scaled wrong with the wrong axis. All have rows as ECT but the numbers are all huge negatives and the columns are supposed to be engine runtime but are huge positive numbers. Looks like its switched and the negative ERT times need to be positive.
  16. #56
    Jun 2014
    36.1094, 115.1781
    432
    First of all, I would recommend starting your own thread in the Dodge Engine Tuning board for issues that you are having while tuning Dodge vehicles.
    This is the PCM Identification Thread which is designated to help those customers who are having issues identifying which PCM their vehicle is equipped with since Dodge introduced so many in the more recent years.
    That being said, I would suggest starting a new thread and include the description in your post. A .HPT file, OSID, and/or screenshot would also be helpful. I looked at those tables in a file I have and the numbers look okay to me.
  17. #57
    Mar 2015
    17
    ok I am trying to read a 2010 challenger but I can not for the life of me connect through the editor. I can connect through the scanner though. The car was just purchased through a dealer and Is magna charged. so I wonder if it is already vin locked? is there a way around this?
  18. #58
    May 2003
    227
    You need to use 2.25. Request it from support.
  19. #59
    May 2015
    1,908
    @ HP Tuners - you list a (4) footnote next to a few PCMs but I do no see that footnote defined, what does it denote?
  20. #60
    Jun 2014
    36.1094, 115.1781
    432
    It's for the supported vehicle list. The text that references the (4) footnote are usually worded as: "All Supported Year Start - Year End Dodge/Chrysler/Jeep Vehicles". So the footnote is the link to the supported vehicle list so you can check if your vehicle is on there.
    It was all the way at the bottom of the original post but I moved it near the other footnotes (as it makes more sense to be with the rest).
