Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 90
Thread: Chrysler/Dodge/Jeep/RAM PCM Identification - VCM Suite 3.0+
  1. #61
    I have a request to calibrate a 2016 6.4 scat pack truck. do we have access to those yet, and does the PCM need to be sent off for write access?
    Phil
  2. #62
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Phil'sC5Vette View Post
    Phil
    Anything 2015 and up requires a PCM unlock.
  3. #63
    Jan 2015
    1
    Quote Originally Posted by szemtrs View Post
    Ok, so I downloaded the beta version, and I still can't get it to read. 2005 dodge ram 1500. I get to where it tells me to Turn ignition Off. Wait 3 seconds, Turn ignition on. And nothing happens, then it says Ignition Cycle: Timed Out. What's going on?
    Update: Ok, I got the TCM to read. When I tell it to not read the ecm and only read the tcm, instead of prompting me to turn ignition off and on in the same window, it pops up a new window with the prompts and then tell me to click"OK" when I have cycled the ignition, and when I click, "OK", it reads the TCM with no issues. It does not do this when trying to read the ECM.
    Im having the same problem with version 3.2.38 anyone know if there is a fix?
  4. #64
    Feb 2017
    1
    I have an 2015 dodge charger R/T i want to get the PCM unlocked i just dont know the stock read number can i get some help??
  5. #65
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by Eugene63 View Post
    Please email support if you need help obtaining the stock read for PCM Modification.
  6. #66
    Tuner Mattechperf's Avatar
    Dec 2016
    Phoenix, AZ
    88
    I'm working with a 2015 Ram 1500 5.7 Sport and I'm trying to find a second PCM to send in for unlocking.
    Is there a list of Mopar part #'s that are applicable for this?
    I'd like to get this right the first time.
    Thanks all.
  7. #67
    Mar 2017
    Detroit
    47
    Quote Originally Posted by Mark@HPTuners View Post
    Is there any way to verify the software version (GPEC2, GPEC2A) via the Continental PCM sticker? I see it says "2012-2016 Chrysler 200 3.6L" is supported, but there was a PCM change from 15 to 16. And with that change, even though the Chrysler part number is the same, there are two different Continental H/W numbers. Mine seems to be the oddball that has "11 bit" on the sticker, where all the PCM's I see on ebay, craigslist, etc.... are a different Continental H/W number, and doesn't have the "11bit" on the PCM ID sticker? Just want to be sure it can be supported before I go spending all the money.
  8. #68
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by gokart2 View Post
    Your vehicle should be supported. If you can, please send support pictures of the stickers on the back of the PCM (there should be at least two) as well as a VIN to verify.
  9. #69
    Mar 2017
    Detroit
    47
    Thank you Mark. Will do when i get a chance.
  10. #70
    Mar 2017
    Detroit
    47
    I used the contact form to send support the link to the post 68, and a quick explanation of what's going on. Could not attach any pics so im waiting for the reply. Should i just post them here? One of the tag numbers is the vin, not sure if there's any negative aspect of posting it?
  11. #71
    Tuner in Training and's Avatar
    Aug 2017
    16
    Mark, 1st of all THANK YOU for this post. Is there any chance we can get something like this for Ford and GM ?
  12. #72
    Nov 2015
    St. Louis MO
    188
    Get on hptuners.com there is a list of every single car they support for every manufacturer.
  13. #73
    Sharmz
    Guest
    anything im doing wrong?, i puled the one IOP fuse same effect, on 60 amp DC power supply. i also manuallly selected the NGC3 from pull down same result, i also tried to read a 2006 G6 also failed? using v 3.6 and MVPI pro cable, i sware 7/10 times this HP tuners cable doesnt work read or support the OS or application, i must either have bad luck or HP missed supporting alot over the years.
  14. #74
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by Sharmz View Post
    Please open a support ticket by emailing support. Include at least one infolog while attached to one of the vehicles in question. If you can obtain an infolog while connected to the 2006 G6 and the 2005 Pacifica, please send both.
    For information on infologs, see: https://www.hptuners.com/forum/showt...acting-support
  15. #75
    Potential Tuner understeerrd@gmail.com's Avatar
    Sep 2019
    Jackson, MI
    1
    Any insight on supporting the 2018+ Jeep Wrangler 2.0 turbo ECU's soon?
    I would be willing to donate some time towards testing/development. Or any other way I can help.
  16. #76
    Mark, I realize this thread is rather old, but I wanted to thank you for providing all of these details, as the ECU/PCM information has helped me with a bunch of things I have planned for the future. Side bar you guys have done wonders for the Gen3 Hemi community.
  17. #77
    2015 durango r/t 5.7
    not reading
    what ecm is this running?
  18. #78
    Mar 2021
    Michigan
    42
    Quote Originally Posted by Lone_mfkn_wolf View Post
    not reading
    15+ requires an unlock service from HpT
    https://forum.hptuners.com/showthrea...Minor-Revision
  19. #79
    Apr 2004
    Keller
    113
    What PCM type to use to read my 2020 Jeep Grand Cherokee Trackhawk 6.2L?
    I tried a read entire and it took 9min 32 sec but not sure it read the TCM, not much info/tables in Trans section.
    Do I need to buy license for TCM to read?
    I'm trying to get a read so I can Purchase a new unlocked PCM from HPT and the site needs the me to send in a Read of stock PCM.
    2020 Jeep Trackhawk, Functional Demon Ram Air Hood, AFE CAI, SW Headers, SW Cats, Solo Cat back Exhaust.
  20. #80
    Aug 2021
    1
    Hi. I have a Jeep Cherokee with a 2020 2.4 engine. I cannot determine the type of control unit. Can someone tell me? I assume that this is GPEC3. And another question, do you need to send a control unit from this car for revision?
