Results 1 to 5 of 5
Thread: Is it ok to leave the MPVI Pro plugged in?
    Nov 2005
    Someplace high in the Himalayas
    770
    I was wondering if it is ok to leave the MPVI Pro plugged in all the time to the port under the dash? It gets its power from there so I'm wondering if it will hurt it.
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    May 2003
    Santa Clarita, Ca
    962
    You can count on a dead vehicle battery.
    That interface uses a lot more power than the serial interface.
    -Ken
    SeƱor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    Quote Originally Posted by Ken@HPTuners
    -Ken
    Agreed 100%...even my serial unit drained the hell out of my battery. My serial unit also started to overheat. Definitely NOT a good idea IMO.
    2008 Viper - now with HPToona - 1/4 Mile Shenanigans Here
    11.02 @ 130
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    that was the only thing that dissapointed me about the design..no on off switch
    it can get power from either the car via the PCM port..or thru your USB...
    needed to be possible thru both due to black box logging....
    its probably easiest just to reach under the dash and pull the plug lose from the OBD port if you really want to leave it in the vehicle...
    but I highly suggest taking the USB box out of your vehicle as its smaller than a lot of cell ohones and you could just stick it in your pocket..
    -Scott -
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    So, in theory, you could leave the cable plugged in, just remove the box. That's easy enough.
    All Motor 2001 GA GT1
