Southwest Speed LLC
5116 Industrial Park Loop NE
Rio Rancho, NM 87124
505-554-9898
https://www.facebook.com/southwestspeed/
http://www.southwestspeed.net
Southwest Speed LLC
505-554-9898
I am really curious what tables are available to modify, but no one has been able to provide a bullet list so far indicating something like this.
Did I read correctly that WG Duty Cycle by RPM is available to change? If so, this should be able to assist with boost drop off for the smaller turbo guys if we can raise WG DC in the upper end to help keep boost planted without falling off as much.
I read on another page that we have the ability to set max torque limitations, is this available on a Per-Gear Basis? If so, this should give us the ability to customize a Boost-By-Gear Function if we can lower the requested torque in first and second to our own set values and let it go full bore in 3rd +.
I read up above that Fuel Tables are now available, so I assume that Rescales are now a possibility? I can buy 800cc Injectors and have them run like stock in not just WOT but cruise / idle as well?
Fan turn on temps are available that I saw, this is great as well... I assume full Ignition Timing Tables are unlocked
Do we know if the Ignition Advance vs Outside Air Temp Table is available to modify? This is typically used to retard timing in extreme cold situations where you dont want to go full savage when its zero degrees outside.
Are we able to modify idle rpm?
I currently own HPT and DL'd the 2.25 Beta but have not had a chance to hook it up to my car as of yet. I am not optimistic that it will currently work due to the fact of me having a Custom Tune on the car currently, I read that HPT is having issues reading Non-Stock Calibrated PCMs currently
Do we have control over the VVT tables?
Thanks for all the help
02 Regal GS
ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
PB-------12.3 @ 110.......312hp/350tq
You should just download the most recent beta, hook up to your car real quick, and read it. I read a 2008 Caliber SRT-4 just a couple nights ago that had Realtune's MS1K v.2 tune flashed to it, and it recognized, read, and allowed editing just like a stock calibration.
It seems that the MS1K tune is based off of a factory OS, so as long as the OS that your tune is based off of is supported, there should be no reason that it won't read/write to the PCM.
so if I order the VCM suite this will work with my caliber now?! I'm so excited...tell me yes and I'm ordering it tonight.
EDIT: Nevermind, already ordered! excited for this!! Been waiting years now.
Tuned my friend's CSRT4 last night with HPTuners! Went from the stock 9 lbs with intake/TBE to a dialed in tune on 16 lbs and 91. Its a totally different car now. With our crappy gas we ended up at 16 lbs and 14.5* up top with no throttle closing throughout the runs. My Dyno will be here next month, then we can get some real world numbers and comparisons from the stock tune to what we can squeeze out on 91, then injectors and E85 right after that
i have problem with the vcm scanner to log any advise?
Just got my stuff, going to scan in the morning! Can't wait!!!
I have only been tuning these on the dyno, with the scanner not having as much strength as the GM cars you really have to take care not to hurt the car Even if they are pretty well built.
has anyone in wisconsin tuned a caliber srt thats on the road? i was just curious because I'm looking at a bigger turbo sometime in the future and bigger injectors. right now I'm running stock turbo with Diablo tune. and NS1 injectors. setup i think i would be getting into is a 20g billet wheel turbo and probably some NS2s or larger injectors just going to run 93 oct
First of all, you'll need to raise all the airflow limiters and torque/power limiters as you know. But, what seemed to cure the last of the throttle pull besides the limiters was under
Airflow > Electronic Throttle > Pedal Power. The Power % Request table drops to I believe 86% in the higher voltage range and higher rpms, so set that all up to 100%, BUT you will have to make sure that the Expected Pedal table is a complete inverse of the Power % Request table, just as it is in stock form. So since the 3.1V column is all 100% now, in the Expected Pedal table the 100% column should all be 3.1 so there are no discrepancies between the 2 tables. With those changes we had no throttle pull on tons of different pulls, 3rd gear and multiple gears. It has since been cold and crappy so we haven't played anymore.
Bryan, I am going to send you something on FB, so keep an eye out.
What are the main maps to increase the turbo pressure in calibers srt4?
