Virtual VE
I’m in the process of attempting to utilize the Virtual VE Correction table in the Beta version, 2.25.1637. I built a histogram to echo the X & Y axis of the VE Initial Correction Factor table using Barometric Pressure and ECT sensors (not PID’s) and corresponding label values. When scanning data, the scanner only populates the first barometric column. Sense atmospheric barometric pressure is not apt to change in a dyno situation, or on the street for that matter, I wouldn’t expect the higher label values to populate. Is that a correct assumption? I have a suspicion that I haven't made the histogram properly.
The BlueCat tool uses MAP and RPM values to make the corrections. This is easy for me to see. I do not understand using Barometric Pressure and ECT and was hoping for some information.
