Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Will not read ECM, but will read TCM
  1. #21
    Aug 2012
    16
    Quote Originally Posted by dnrprojectsvp View Post
    i have the same problem, i cant get it to read. it says make sure its on RUN but it is KOEO. i am able to scan the vehicle. Its on a Chrysler 300 SRT8
    I can scan mine also.
    When I hooked up the Diablosport InTune, at first it told me my vehicle wasn't compatable, but it said to plug in to a computer and it would download a new PCM configuration file. I did that and it downloaded a new file, installed it on the PCM, and then everything worked just fine.
    There's something not meshing up with HP Tuners and a few of these PCM's it seems.
  2. #22
    Feb 2006
    South Carolina
    1,525
    That sounds like it's not seeing the ECU at all, or the interface. Make sure the scanner is also disconnected prior to trying to read/write.
  3. #23
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by szemtrs View Post
    That was an OS update. Diablo tends to work off the latest release so they provide the update before they flash their changes.
  4. #24
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,262
    I've done that, and the 2 replys I've gotten were that I have a wiring problem, or the SCT tuner messed something up. Which I know both are not the case.
    shoot me a email directly, bill @ and I'll have you send in your interface so we can at least rule that out as an issue.
  5. #25
    Aug 2012
    16
    You are the person I've been emailing directly already.
  6. #26
    I know this is a dodge but I did a mustang and it would not read. Until I opened the door when doing the key cycle. Didn't make sense to me but it worked. Almost like it was not shutting down some modules until the door was opened
  7. #27
    Aug 2012
    16
    Quote Originally Posted by tokymon View Post
    I've tried that and every other trick people are coming up with. It still wont read. The Diablosport InTune is working great on my truck. It's weird that one brand will work and the other won't . I'd really like HP Tuners to work so I can tune myself and not have to pay someone to do it.
  8. #28
    HP Tuners Support
    (foff667)
    28,262
    I assume you emailed me to have your interface sent in to be tested?
  9. #29
    Mar 2021
    4
    I know this is an old thread but was the problem figured out. I am having this same issue with an 04 ram but cannot read either TCM or PCM
