Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Fuel Pump Run
    Nov 2007
    232
    Fuel Pump Run
    I know there is a way to do it as I had an sct tune that did it. I no longer have my sct box so I can't just use that. What tables/parameters do I need to set to have the fuel pump run constantly as to drain the tank to switch to other fuels?
    Thanks in advance.
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
    Oct 2014
    8
    In SCT its under Returnless Fuel Pump. Set the Duty Cycle When Pump is Off to .5.
    Nov 2007
    232
    Same location on hpt?
    Jun 2006
    Rham, NC
    155
    I have never tried it, but it looks like there is a switch for turning the fuel pump on in the VCM scanner.
    Current toy- 97 SCSB OBS chevy forged 6.0/4l80 combo with a bit of boost..currently back under the knife
    To many previous vehicles to list
    Mar 2014
    309
    The attached should help.
    Nov 2007
    232
    Ok, so taking what you're saying there wbt, I've looked at those tables. I may be interpreting them wrong.
    Minimum On Time: I read as this is the priming time frame. Pump will run for in the case of your image for 8 seconds
    Secondary Monitor: Reads as a pcm test. Maybe something to do with the evap system
    Rail Pressure: Pretty self explanatory there.
    Off Duty Cycle: No freaking clue. Duty cycle when pump is off. My brain immediately says this should be 0 because if the pump is off...then no duty cycle is required.
    But thanks for refreshing me on those...re reading what jmac posted it makes sense, I'll have to give it a shot.
    Mar 2014
    309
    Quote Originally Posted by schaid View Post
    Correct. Try cranking up that Minimum On Time to 1,800 (30 min.) and see if that does the trick.
    Nov 2007
    232
    Max setting in that table is 32 seconds.
    Mar 2014
    309
    I just noticed that......hmmmm. In the same boat as you....looking around I am unable to find another parameter listed that will control the prime timer. Maybe Eric can chime in.
    Oct 2014
    8
    Cant speak for HPT as I still havent pulled the trigger on it yet. Judging by wbt's screenshot, you need to change the Off Duty Cycle to .5. No other changes should be needed.
    Oct 2007
    Crawfordville, FL
    2,412
    Change the Off Duty Cycle to .5 and it will run.
    Eric Brooks
    HP Tuners, LLC
    Nov 2007
    232
    Sweet!!! Thanks guys. I had gathered that from taking jmac's wording and wbt giving me the virtual slap upside the head saying hey dude...check here! Thanks for confirming Eric!
    Mar 2014
    309
    Just an FYI. I did this over the weekend and worked like a champ.
    Nov 2007
    232
    Awesome! I will be using it as well very soon as well. The vehicle I needed to know it for was significantly lower on fuel than I was told so it was not needed...that and I had to jump through hoops and play games getting it unlocked.
    Nov 2013
    5
    Any idea how to get the fuel pump to run to empty the fuel tank in 3.6
    Just need to get 10 gal of fuel out
    2011 camaro ls3
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Quote Originally Posted by spd2612 View Post
    2011 camaro ls3
    I think in camaro's you can PROBABLY do it through VCM Controls/special functions in the scanner...
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Any chance setting the min to .5 to run the pump could be added to the logger as a switch?
    What is different on a Gen 3
    Nov 2017
    detroit
    5
    does this work the same with 2018+ gen 3 coyotes
    Sep 2021
    1
    Resurrecting this thread. Was curious if there is a way to adjust the pre start fuel pump prime time (FP prime when you touch the break before start) in HPtuners. It's a 2015 GT with a Fore triple pump return style setup. Thanks.
