It seems as if the mph limiter will not allow the car to go past 155mph no matter what it is set to. Maybe disabling the abs for a dyno pull may be needed for now. Anyone else having this issue?
What RPM are you hitting at 155 MPH?
Eric Brooks
HP Tuners, LLC
Ran into this today. Any help for us speed junkies?
You are more likely hitting your output shaft speed limit, look in the transmission section, set to 16,000rpm to move it out of the way(at your own risk)
Would disabling GEAR BOX LIMIT help for a manual trans car?
