Results 1 to 6 of 6
Thread: Injector Calc Spreadsheet
    Aug 2004
    Franklin,OH
    215
    Attention Boostjunky and other experienced Mopar guys.....I made an injector data spreadsheet to help me easily change data for new injectors. If you could ,please play with it and let me know if the math and concept is correct.Dodge Injector Calculator.xlsx
    Apr 2014
    704
    Looks good, but I would suggest extending the decimal place of the ms values to the 1/100,000ths range (x.xxxxx ms), as this is the resolution that the tables actually use (they are just rounded the the nearest 1/100th in the main table - click on the axis label to see the true, unrounded values of the "Fuel Mass vs InjPW" table).
    This will end up being a pretty handy spreadsheet. Thanks!
    Aug 2004
    Franklin,OH
    215
    Thanks for your input. I really appreciate it.
    Dec 2014
    Palmetto, FL
    874
    Badassbird is the Spreadsheet in your first post the most updated spreadsheet that you currently use?
    Thank you
    Aug 2004
    Franklin,OH
    215
    Made some changes.
    Dec 2014
    Palmetto, FL
    874
    How do you find Startup InjPW Scalar? And also how about the Startup InjPW Tables?
    Thank you for the updated Spreadsheet.
