Attention Boostjunky and other experienced Mopar guys.....I made an injector data spreadsheet to help me easily change data for new injectors. If you could ,please play with it and let me know if the math and concept is correct.Dodge Injector Calculator.xlsx
Looks good, but I would suggest extending the decimal place of the ms values to the 1/100,000ths range (x.xxxxx ms), as this is the resolution that the tables actually use (they are just rounded the the nearest 1/100th in the main table - click on the axis label to see the true, unrounded values of the "Fuel Mass vs InjPW" table).
This will end up being a pretty handy spreadsheet. Thanks!
