Results 1 to 10 of 10
Thread: 2001 2500hd lq4 power enrichment
    Oct 2012
    15
    ok guys ive done some tuning to the power enrichment, mainly just made it so itacually comes on and is tuned to 12.9-13.0 at WOT. the throttle position is still 90% which im assuming is higher than i want. ive just kinda started tuning, havent messed with timing. i attached my tune, if anyone sees anywhere i can make improvments
    13,565
    You can move the throttle % down to say 60-70% but then just set the enable KPA from like 55 to 70-80 so that will trigger when PE enables. It waits for the load to be there.
    Also you set the delay to 60 seconds, switch that back to 0.0. And the enable torque is set to 100% but most of the torque mngt on the engine side has been disabled, so going down to 80% might help some.
    And 12.9-13.0 is pretty lean, hopefully you have a wideband. I'd shoot for something more around low to mid 12's to be safer.
    Oct 2012
    15
    cool i will make some adjustments, i understand everything but the delay at 60 seconds. im not seeing that
    May 2013
    13
    Is this really considered lean for WOT on an NA motor??? Around what i was running with 35psi on a 1.8l turbo VW. I always was under the impression you could run leaner on NA. AKA just under stoich.
    13,565
    They say lean is mean, but sometimes you are just risking everything.
    I'm no tuning guru nor do I have tons of experience with different cars but the norm is 11-11.5 AFR for supercharged/turbo cars as a guideline and 12.5 for NA motors.
    Coming from the 3800 world, they never liked running much leaner than 11.8ish with 93 octane fuel as knock started to pop up in the higher rpms. E85 is another story and I never went there, you could run leaner with E85.
    Another that comes to mind is how much ethanol is in the fuel, figure if 10-15% in some states it might like to run a tad bit leaner than 12.5. And as for your VW, I'm suprised it lived with 35 psi at 12.5+ air fuel ratio.
    13,565
    Quote Originally Posted by ullose272 View Post
    Engine > Fuel > Power Enrich > PE delay.
    It's on the very bottom, says rpm delay of 1,400 and delay at 60.0 seconds.
    Make sure you are in advanced mode to see everything.
    Oct 2012
    15
    ya i have it in advanced and only the rpm delay shows up
    13,565
    Odd, maybe my version of 2.24 is newer than yours.
    Never hurts to download the newest version from your customer page.
    Jun 2012
    225
    I just looked at your tune and I can see it.
    Oct 2012
    15
    Weird i cant see it at all. Im pretty sure i have the newest. ill look when i get home
