need a runing for my 2001 silverado its 5.3l or stock add headers
Any tuning file can help me out
Do you own a wideband??
And what is your exact question?
Your VE table is way way off, you have numbers in there that a NA motor will never see. A 1 bar map cannot see over 100 kpa and you are way up into the 130's.
I'd return the VE table to stock and start over and use a wideband to tune the VE and MAF.
Thanks for you time
Im looking for stock file so i can compare
Yes i have afr500 wideband with ngk sensor will arrive end of this week and i will start over
