Results 1 to 13 of 13
Thread: 2005 LLY Tune Problem
    Jan 2014
    West Texas
    13
    Ok, I'm a novice on HPT, so be easy on me. Working on Father-in-laws C3500. I have tried my own 20/20 tune, but wasn't happy with results, too "peaky". So I followed the "McRats 20/20" guide and we really like this tune. Only issue we notice is the Idle. For lack of a better description, it lopes? or as he says, it "chuckles". I'm thinking an injector timing issue, but looking for advise from the skilled tuners on here. Thanks in advance. Tune files attached, I hope.
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Looks like you have increased injector pw at idle you can return all cells from 30mm down back to stock
    Mar 2015
    5
    no need to change fuel at idle unless you want more smoke
    Jan 2014
    West Texas
    13
    Thanks for the insight guys. Made changes to tune, will go out and reflash shortly. Ill post up results.
    Thanks again!
    Jan 2014
    West Texas
    13
    ok, made the suggested changes to the tune. Re-flashed to vehicle, started it and everything sounded great. He calls me this morning, and said its back doing the same thing. Chuckling/loping idle. So, do yall think this is a fuel qty issue? or a timing issue?
    Dec 2014
    Terrell Tx
    478
    Post current tune and do a data log and post it too with fuel pressure and mm3 pids in the table
    Mar 2015
    5
    xxxx2
    Dec 2013
    Burkburnett, Texas
    28
    Put stock tune on it and see if it still does it. If it does then it's probably the FPR (Fuel Press. Regulator)
    Tuner Howes's Avatar
    Apr 2015
    NH
    130
    i agree w holland
    Nov 2010
    18
    EGR issue?
    Apr 2015
    1
    look at the PW tables (main pw, main pw no pilot and pilot pw) they are really high. I would put those back closer to stock. I don't know what else is changed over stock but the pw tables for the mild tune I did on my lb7 was just the all the pw tables multiplied by 1.2 and it worked good.
    If it is fluctuating at an idle just slightly every three to five seconds a slight surge then drop it is a FPR causing the issue
    Oct 2016
    Virginia
    28
    let me know what results you get i was having the same issue with a lly i am tuning
