hey guys have here A 2015 Silverado 1500 6.2,
under the truck was a wire harness for the flex fuel sensor just like the 5.3 all power and ground work, on the ecu (correct me if I'm wrong the top connector) x1 connector pin #38 like the c7
already has a white wire there which is the same on the harness for the signal added the 13577429 flex fuel sensor near the harness if everything is go form here all I need are the correct Pids thx for looking and any help
