Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 110
Thread: New Users: Help files and Demos
    Sep 2002
    Chicago, IL
    6,395
    Arrow New Users: Help files and Demos
    Help Files:
    Please take a moment to review the help file as alot of common questions
    can be answered from it. Also, check back after every software update as
    new content is being added all the time.
    You can open the help file at any time in the Editor or Scanner by
    pressing 'F1'. It will take you to the section of the help file that relates
    to what is currently open in the scanner or editor.
    Example: If you have the spark advance section open in the editor and
    press F1 it will take you the the spark advance section of the help file.
    Note: At this time if you have the help file open by hitting F1 you will not
    be able to switch back to the scanner or editor until you close the help
    file.
    Current Users can also access it direct outside of the program by:
    Start->programs-> HP Tuners-> 'VCM Suite Help'
    ...this would be your best option if you want to use the scanner and/or
    editor at the same time as the help file as you will be able to switch back
    and forth as you please.
    Future HPT Users can Download it here (right-click, save-as):
    http://www.hptuners.com/pub/VCM Suite.chm
    If you download the help files but cannot view them in Windows XP:
    Right click the VCM suite.chm file and click properties. On the general tab look to see if there is button that says "unlock", click the button to unlock the file, then double click to open the file and it should open.
    You can also view the help files online:
    http://www.hptuners.com/help
    Demos:
    You can view online demo's of common VCM Suite tasks:
    Installing the MSI installer
    Installing MPVI Drivers Windows 7 64 bit-NEW
    Saving a VCM Suite Info Log-NEW!
    Where to find your .os, .cfg, & .hst files
    Invalid vin/os pair error
    Definition failed to load error
    Setting up the E38/E67 2.5 bar custom operating system-New, 12 minutes long
    Reading your VCM
    Writing Calibration to the VCM
    Failed VCM Calibration Write - VCM Recovery
    Changing Fan Settings - 160 Degree Thermostat
    Applying a 1 Bar SD Enhancement
    Applying a 2 Bar SD Enhancement
    Basic Scanner Startup Demo
    Adding and Removing PIDs
    Creating a Custom PID and Adding a Custom PID to the Histogram
    Creating a user defined EIO Input
    Standalone Data Logging-NEW!
    Creating and Saving Custom Histograms-NEW!
    Using Plot Filtering in Histograms
    Reading and Saving DTC's-NEW!
    Opening a config file in VCM Scanner
    CASE Learn
    MISC
    Taking a screenshot
    We got this guy Not Sure, ...
    28,266
    TTT Added a bunch of new demo's
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Bill,
    Would you please update the 1998 F-Body gear change demo. GM uses 24.9 as the stock tire dia. This applies to both a 245/50/16 or a 275/40/17 tire. A lot of people are using the advertised/measured tire dia when changing gears or tires.
    This then causes no wot upshifts and inaccurate speedos.
    Russ Kemp
    Not A Tuner
    Oct 2006
    977
    Bill
    Nice to see more demo's
    THANKS
    DH
    2004 MSG A4
    Appearance: Billet Plate&Sill/SS Insert/Screens/Blackout/Lowered/CCW SP500
    Perfomance: 416 CI/228-232@114/AFR 225/FAST/LS2 TB/36#Injectors/Honker/RPM(IV)/Vig2400/Z06 Ti/Kooks/3.42 Gear/Hotchkis/Bilstein/Z06 Springs/Eradispeed/Hawk HP+/Trans Cooler/B&M Trans Pan/RonDavies with EOC/Nitto R2's/AMWcan/Rocker Rails/Frame Savers
    Mods & Tune: A&A Corvette
    ??? RWHP / ??? RWTQ
    1/4 mile: mid 11's ??
    WSIR 1:37.68
    28,266
    Quote Originally Posted by Russ K
    Bill,
    Russ Kemp
    I'll get it updated asap, again the demo is a general demo. People do occasionally change their tire size as well
    28,266
    Updated Russ
    Jul 2007
    8
    Maybe something that talks about the DOD on the LS4 cars? Since I am new to all of this, I have read everything I Could, but I am still lost as to what I should change once I get my tuner. I was thinking that since alot of people have the LS4 with DOD, they want to know if the best thing is to keep it or disable it and then the best way to tune an LS4 car.
    28,266
    Quote Originally Posted by TazSS34
    For liability reasons I really can't get into showing you how to tune things like that. That is what this forum is for...so you can test, tune & share your experiences with each other.
    28,266
    Added a few more this morning that were in the help file but not in the thread.
    Feb 2007
    254
    Those are great! I watched just one and learnd some things I didn't know about the program.
    28,266
    Added a new one on how to perform a CASE learn using a new tool, tell me what you think
    Does the case learn work on version 2.1.18.0 ?
    28,266
    It should, thats what version I used for that demo.
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    Nice demo aread guys. Thanks.
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
    Advanced Tuner colamotas's Avatar
    Oct 2006
    277
    very effective!
    SRT 10 without any mods. But still hella fun too drive.
    93 fox coupe with a 427 in the works.
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    thats some great info regarding the I6 gear/tire!! thanks!
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Jan 2008
    Florida
    4
    OK, I have 2 things to say. 1. Wow the demos are great and 2. Would it be possible to do a demo of a start to finish tune on a new set up...wether it be a cam, head/cam, stroker, turbo...whatever the mods are but requires a from the top tune, showing step by step?
    Just a thought.
    BTW, I tried to attend one of those classes but being in the military ended up being gone during the class and lost my hundred dollar deposit. Not upset about the deposit...upset that I had to miss the class, would have been a great start for me.
    2002 Arctic White, A4 Camaro SS currently undergoing surgery...so far lasting since Oct. 6, 2007.
    28,266
    1. Thanks Both Scott & I worked very hard on them
    2. No, with support of dozens of different pcm's and probably over 1000 different operating systems each different from the next it would be impossible to do one for each of those operating systems. And how to tune a cam, heads/cam, stroker, turbo, SC, would each require their own demo your talking 5000+ demo's, sorry but that isn't going to happen, also it becomes a liability for us to tell you how to tune, because if theres something incorrect in the demo(or even if its correct) & for some reason you pop your motor you can come back claiming well this is how you told us to tune & it blew my motor.
    Just a thought.
    Advanced Tuner Braciole's Avatar
    May 2008
    New Jersey
    227
    Bill is there a demo of the DTCs??
    How to remove codes? etc??
    Mike
    2007 C6 coupe LS3 416 6 speed mn Z51 3LT
    Vararam Snake charmer 160 Stat
    Kooks 1 7/8 headers with jet hot
    Fast 102 ported intake 102 TB RPM Level 5 T56
    MGW short throw ZIP 4.10 Severe Duty rear
    RPS TWIN DISC CARBON CLUTCH CCWs ele wp
    RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
    http://www.youtube.com/watch?v=PtOPy_lp2QY
    10.66 1.47 60ft 133+mph
    28,266
    Quote Originally Posted by 1BadC6
    Mike
    Anything related to emissions is not allowed on this forum.
