Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 110
Thread: New Users: Help files and Demos
  1. #61
    Jan 2010
    1
    i have a problem i have just put a turbo on my 03 silverado and i did a 2 bar speed den tune and whe i did it the truck turns on for 5 sec and then reduce engine power turn on so pls can some one help me
  2. #62
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    you may have to set the tps/maf compare tables in the engine diagnostics page to a higher/lower value...
    check which code it throws to see which table it is looking at.
    -Scott -
  3. #63
    What is the different between:
    1 Bar or 2 Bar SD Enhancement?
    Adding and removing PIDs?
    Please
  4. #64
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    1 bar-up to atmospheric pressure
    2 bar-up to 14.7psi of positive boost pressure, meant for boosted applications
    Adding would be adding in scanner data
    removing would be removing scanner data
  5. #65
    Apr 2010
    riyadh
    5
    those demomstration are sure and very helpfull
  6. #66
    What about the E38 2.5 BAR SD upgrade?
  7. #67
    Jul 2009
    2
    how do i get the debug fiel? does it have to be hooked up to car?
    thanks
    d
  8. #68
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by Big_Bird_WS6 View Post
    thanks
    d
    debug file is only available in the newer beta's and is found in your hptuners-settings folder(the same spot as the license.dat file).
  9. #69
    lag time
    hi how we can remouve the lag time on gen iv car ? throttle responce ? thanks
  10. #70
    HP Tuners Support
    (foff667)
    28,265
    tq management, etc tables as well, there are likely some TAC module tables that control the throttle in these applications but we can't access those so you are limited to whats in the pcm.
  11. #71
    Oct 2010
    8
    Great post i will definitely going to learn alot of this!
  12. #72
    Mar 2011
    Mid West
    97
    Very good demos keep the love coming..
    Mr. 2008 SS
  13. #73
    Mar 2011
    Mid West
    97
    Any input on E 85 fuel tables, injector, adding more fuel for lean conditions. I want to use this fuel for more power but I know it will make my engine run lean...
    2008 SS Trailblazer AWD LS2, catback k@N up front
    Thanks,
    Mr. 2008 SS
  14. #74
    Oct 2006
    South Carolina
    171
    I almost forgot about all of the demos! I'm going to become a "superhero tuner"!
  15. #75
    Apr 2011
    7
    This should really be a sticky. I have been thinking about buying hpt and this thread just sold me I think
  16. #76
    May 2011
    Tulsa
    45
    Guys,
    I bought the begginers version of the tunning school and it set me way ahead in my learning curve. I have a charger and there is a specific section on charged and turbos, They also have one on heads and cams. It has a book so you dont have to keep trying to stop the video and go back and forth. The book shows the actual table and tells what it does and how its affected. Yea your going to drop some money in it but education of any kind can never be taken away. It was well worth the money. Hope this helps. I had the same problem with the boost. I did it both ways and still nothing. Now I know that it has to have a 2 bar instead of the stock one. I have a boost guage in the pillar post. I just went from 6 to 9 lbs. It was a good challenge, however the book was great.
    03 Z06 Magnacharger, Borla stingers with XP Stainless Headers,KB Boostpump, 42 lbs injectors, 160 stat. CAI3.TPS Motorsports 427 Shifter. AFX Powerdex wide band. TIC clutch master.Monster stage3 with 18 lbs flyweel. AFX wideband. 10LBS boost. ALKYCONTROL methanol injection. DTE Trans Brace, Built MN6, NGK Iridium 7IX , 2 Bar MAP.
    [email protected]
    www.haysauto.com
  17. #77
    Apr 2010
    223
    Quote Originally Posted by jetaws6 View Post
    I agree, although I think it is referenced and linked to in one of the stickies ...
    J. J.
  18. #78
    HP Tuners Support
    (foff667)
    28,265
    65,000 views and counting...every user should watch all the demo's at least once
  19. #79
    Tuner RooTBeeR's Avatar
    Feb 2009
    Chino, Ca
    106
    ^agreed, well worth the time infront of the screen
    Caution:Slow Learner
  20. #80
    Aug 2011
    7
    Trying to install HP Tuner software on laptop with Windows 7 and could not get it to work. I have now installed it on an older laptop with Windows XP and says my application key is invalid. Please help! [email protected]
