Results 1 to 2 of 2
Thread: th400 kickdown
    Feb 2015
    6
    th400 kickdown
    is there a output off of my stock 2000 5.3 pcm i can use as a kickdown for a th400 working off the tps?
    Sep 2018
    1
    I am also looking for an answer to this. Is there anything that is triggered (ground, 12V, etc) from the PCM based on a wide open Throttle Position ? (Maybe A/C disable?)
    Need either a ground signal or on/off 12V to trigger a relay and send the trans a 12V signal at WOT.
    Thanks for any help!
