Results 1 to 3 of 3
Thread: automatic, in manual mode..increase shift speed
    Aug 2016
    23
    got a 2016 silverado with the 6 speed auto, and the customer wants me to make the transmission shift faster if not instantly when in M1-6 mode on the column shift.
    is this possible?
    13,582
    It will never be a instant shift, that isn't possible with this type of transmission. It takes time to select the next gear and more fluid around.
    You can try and play with shift speed and pressure presets but you'll only get so far. This customer has to remember that this truck weighs 5,500lb still, going too quick will end up slamming gears and being all clunky/lurchy. A lighter car can get away with a little more because it doesn't have the mass behind it.
    Aug 2016
    23
    ok thanks
