Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Any others taking on an F150 Ecoboost?
    Feb 2006
    Canada
    1,958
    Friend of mine has had a handheld tuner on his truck for a while, its horrible. The good guys at HP*Thank you BIll*have made it possible for him and I to get into his tune. I won't see him for another two weeks, but here's MY problem. The file I submitted cannot be viewed, I need his truck to be able to scan it again and view his file. I'm hoping one of you fine gentilmen/ladies could post a stock file for a 2013 F150 Ecoboost! There in't a Ecoboost file to be had in the Repository. Can you help?? Either here or a stock file uploaded to the Repository would be great!
    2000 Trans Am WS6
    Oct 2007
    Crawfordville, FL
    2,410
    Here you go.
    Eric Brooks
    HP Tuners, LLC
    Feb 2006
    Canada
    1,958
    Thank-you very much Eric, that's perfect!
    2000 Trans Am WS6
    Jul 2011
    Fort worth, TX
    126
    I will be trying to take on my 13 Ecoboost tomorrow
    Jul 2011
    Fort worth, TX
    126
    Tried to read my 13 f150 ecoboost this morning and it said it couldn't be read and it generated a generic stock file
    15 C7Z M7
    Feb 2006
    Canada
    1,958
    Submit it all to support, William will fix you up. .hpt file, vcm suite info file for the truck and the debug.dat file. I almost always forget to attach one of them myself. Make Bill happier than I do and attach all three right from the get-go... and yes Bill, this is my way of saying Im trying to remember all three files bud! hahahaa....
    2000 Trans Am WS6
    Oct 2007
    Crawfordville, FL
    2,410
    Quote Originally Posted by Tiffo60 View Post
    You can force a read, after you click get info, there is a drop down to select Force Full Read. It takes about 4.5 hours to read, so use a battery charger.
    Jul 2011
    Fort worth, TX
    126
    I saw that option just didn't know the what/if I could hurt doing that lol, I also emailed support with the attached files as recommended earlier
    Feb 2009
    4
    I currently have a custom SCT tune on my 13 Eco F150. Will I be able to read the custom tune, or should I revert back to stock before reading. Ideally I would like to read both and compare the stock tune with my custom tune and make small changes. Thanks
    Advanced Tuner Japeatr's Avatar
    May 2010
    Dallas Texas
    321
    I am working with mine, so far just adjusted tires size and deleted top speed limited.
    I need cam tables! waiting on 2.25 beta.
    384whp/303wtq
    Built 2.0LSJ: TVS w/2.6, 1000cc, Stage 2 cams, custom fuel system, E85, Dual Pass, 3"intake, 3" Catless exhaust, CIA midlength Header
    Oct 2007
    Crawfordville, FL
    2,410
    Quote Originally Posted by sknapp302 View Post
    You can read it.
    No need to read the stock tune, the normal read will look at the OSID that is in the truck, and serve a stock binary image from our database. We did it so that you don't have to wait 4.5 hours. Probably is we do not have every stock file in the database, so if your doesn't come up, email us, and I will go and find the stock image and add to the DB.
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,410
    Quote Originally Posted by Japeatr View Post
    What cam tables do you need? They ecoboost VCT controls are there.
    Eric Brooks
    HP Tuners, LLC
    Feb 2009
    4
    You can read it.
    Awesome, thanks!
    Tuning Addict
    Jan 2015
    6,783
    Was just trying to read a 2011 ecoboost and received an unusual message. My first time trying to use HP with Ford.
    The data you just read isn't from your vehicle. Your vehicle isn't readable. The data is a supplied check file. If you use this data to write your vehicle you will loose any existing changes your vehicle may already have.
    I am assuming this is because you don't have a stock database file to go by? Then thought vehicle was possibly already tuned, but not the case...
    Also noticed in this supplied check file, I have no MAF tables or atleast none that I have found?
    ~Greg Huggins~
    May 2010
    Dallas Texas
    321
    I cannot get many of the pids on the scanner, so I would be flyin blind on adjusting the cam tables.
    384whp/303wtq
    Oct 2007
    Crawfordville, FL
    2,410
    Ah, yeah, that will be fixed very soon.
    Eric Brooks
    HP Tuners, LLC
    Jul 2011
    Fort worth, TX
    126
    I can't get a histogram to work to save my life. Ive tried all sorts of sensors and configurations...
    15 C7Z M7
    Jan 2013
    22
    I'd love to start tuning mine, but I'm gonna wait until the scanner is finished. For starters I can't read any DTC's or see anything to do with tranny. Plus when the time comes, I'll know what NOT to do from others experience.
    Jul 2011
    Fort worth, TX
    126
    Quote Originally Posted by splashgtp View Post
    Im with ya, Im trying to do a full read on mine right now(4hrs lol), its flashed with an sct tune and i am hoping it will read it all so I can compare it to a stock file and see what the mail order boys are changing....
    15 C7Z M7
    Tuning Addict
    Jan 2015
    6,783
    Were you able to get the tune out this way? I keep getting the message in my last post when trying to read the stock file for an 11 ecoboost.
    ~Greg Huggins~
