Page 56 of 64 FirstFirst ... 646525354555657585960 ... LastLast
Results 1,101 to 1,120 of 1261
Thread: VCM Scanner 2.25 Beta Now Available
  1. #1101
    Tuner OldFartC6's Avatar
    Jan 2008
    North GA
    188
    Quote Originally Posted by jtrosky View Post
    I think he meant do you mind sharing your config! :-) Like posting the files here so that others can use it on their PC.
    Oh stupid me. Here you go.
    Edit: added file -
    My Custom Gauges.Gauges.xml
    Gauge properties.GaugeDisplay.xml
    Check out the added logo:
    Last edited by OldFartC6; 01-03-2016 at 01:25 PM. Reason: Might need this file also.
    2006 LS2 Corvette
    Automatic
    2.56 gear
    600 HP Edelbrock E Force Kit
    No other mods
  2. #1102
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by OldFartC6 View Post
    Edit: added file -
    That looks really slick! I'll take a look at the config in the morning
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  3. #1103
    May 2010
    Behind the wheel
    272
    This reminds me of a problem I stumbled across weeks ago. When I make and save my own layouts or load old layouts, I get all the parameters from the current layout plus the layout I just loaded. The result is I have to manually delete each item within the layout before loading a new layout. Has anyone else experienced this? Is there a way to mass delete the current layout or just switch to the new layout without it appending the current layout? Maybe there could be an option to append or switch to the next layout.
  4. #1104
    Sep 2002
    Chicago, IL
    6,395
    that's by design, when you use the individual controls (graph/chart/gauge) to save/load layouts.
    If you use the main layout engine (on the menu or main tool bar), it will remove what you have, and load what you open.
    We got this guy Not Sure, ...
  5. #1105
    Oct 2011
    QLD, Australia
    436
    Keith did you have a win with the MTX-L Innovate stuff? Are we able to account for ground offsets?
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
  6. #1106
    Jan 2008
    North GA
    188
    Math routines
    It was requested that I post these math routines.
    Boost.MathParameter.xml
    HP.MathParameter.xml
    TQ.MathParameter.xml
    There is a fudge factor of 1.15. You will see it in the formula. I used it to match previous dyno results. Anybody that uses this formula will have to adjust it or do away with it.
    2006 LS2 Corvette
    Automatic
    2.56 gear
    No other mods
  7. #1107
    May 2010
    Behind the wheel
    272
    Quote Originally Posted by Keith@HPTuners View Post
    Got it, thanks. It's actually a cool thing - if you realize it's going to happen. It just made me wonder about my sanity a bit when I duplicated everything I had.
  8. #1108
    Mar 2008
    12
    VCM Scanner 2.25 supports wideband inputs via both MPVI AD and PC serial port.
    the scanner sees the serial info in the channels but the math is off, 14.xx is 47x ect inno afr and inno lambda both display the same 47x numbers there needs to be a formula for the raw serial data.
    would like to get the serial wideband logging correctly
    thanks
  9. #1109
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    serial data is too complicated to just have a simple transfer function like you can with voltage inputs
  10. #1110
    Mar 2008
    12
    right the serial data that they have im assuming is a raw value of sorts, would just like the logging of that data to work.
  11. #1111
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I'm sure they can make it work. You need to give a clear description of what wideband you're using, what it's displaying, etc. so they can fix it though.
  12. #1112
    Jan 2009
    Spokane, WA
    480
    I'm not able to get my LM-2 to work with 2.25, through the USB port. Am I doing something wrong? Or is this not supported yet.
  13. #1113
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    Quote Originally Posted by waynehartwig View Post
    I try that so often and its not possible to show the same values like the LM-2 Monitor. analog output is very noisly and the serial show's wrong values.
    Here in the forum are a lot of innovate users who can't get it usable...
    I ordered now a Zeitronix ZT-3...that works good!
  14. #1114
    Jan 2009
    Spokane, WA
    480
    Quote Originally Posted by Auto-Hentzschel View Post
    I have zero issues with using it in 2.24, as long as I use the same ground. It's a voltage reference, and it's referenced off the ground. If you use different grounds, then the values will be different.
    I can't get any value to come up through the USB on 2.25, wrong or right.
  15. #1115
    Sep 2015
    Schleid, Germany
    341
    my LM-2 serial works with 2.25. try it without any other USB device in the Laptop! If I use it with other USB connectors pluged in. no input to the scanner
    BTW: I try a lot of different ground, together, single, direct battery, chassis, 12V output. every was the same. unusable. inavate support don't write an answer. never again.
  16. #1116
    Sep 2015
    Schleid, Germany
    341
    hope Keith will add the ZT-3 serial input soonest!
  17. #1117
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Is "through the USB" connected to the external inputs on the interface or is that going to a serial to USB converter?
    If you're using the external inputs on the interface then you are doing something wrong if nothing is coming through
  18. #1118
    Jan 2009
    Spokane, WA
    480
    USB = serial. Running through the MPVI interface it works fine in 2.24. I haven't tried through the interface in 2.25, but I'd imagine it would work there as well, I just haven't tried. I'd like to start moving over to 2.25....
  19. #1119
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Then just connect it to the interface and be done with it. If it worked fine in 2.24 it will work the same or better (much faster) in 2.25
    Keep in mind 2.25 logs a LOT faster on external inputs... so you'll see more quick up/down variation than you're probably used to seeing. I've started averaging external inputs over 100msec or so just to smooth them out
  20. #1120
    Jan 2009
    Spokane, WA
    480
    2.25 is supposed to be able to do USB inputs. The question I posed was if it was available yet. Not that I am stuck on the dyno and my customer is pissed that he's wasting his time with a noob.
