Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 141 to 160 of 198
Thread: Flex fuel
  1. #141
    I'm also noticing on my 2017 the ECM 21320 - Flex Fuel Ehtanol % vs. AFR is all 14.6 on the left, on the F150 it's 9.0 and 14.6 on the bottom. Is this causing an issue?
    Where as my 2017 looks like this:
    This seems like it could be the problem. Any ideas?
  2. #142
    May 2016
    1,134
    That will cause a problem. That's the main lookup table for calculating ethanol content. On the row axis is the stoich AFR and the value is the reference ethanol content. Having this 9.0 100% and 14.6 0% tells the computer to calculate ethanol based on a linear relationship between these two points.
  3. #143
    Any idea on how to fix this, or what I can do?
    Interestingly enough this table isn't in the 15, or 16 mustang file either and people appear to be having success with them. Am I missing something?
  4. #144
    May 2016
    1,134
    It's in there unless I'm confused by what I'm looking at. Post your tune or email it to me at [email protected]
  5. #145
    What I should say is the table is there, but the entire axis is just 14.6, there is no 9. So there's no Air-Fuel ratio for ethenal in that 21320 - Flex Fuel Ethanol % Vs AFR table.
    I shot that over as well.
  6. #146
    May 2016
    1,134
    I responded to your email with a screenshot for how to change it.
  7. #147
    Got it! Thank you, it's been awhile since I've dabbled in it.
  8. #148
    May 2016
    1,134
    No problem.
  9. #149
    has the cold start emissions retard issue been fixed?
  10. #150
    May 2016
    1,134
    I've been watching and haven't see the new tables yet. I'm guessing they will make a post about it when they fix it since so many people need this but hard to tell.
  11. #151
    Sep 2010
    872
    Quote Originally Posted by ridenrunwv View Post
    Eric had replied to me about it and asked me to email support. Since I had a open ticket with Corey for this issue already already I went ahead and emailed him
    - HPT info log
    - Copy of tune
    - Copy of datalog
    - Image with labels showing the issue(attached to this post as well)
    - Images of Eric's post telling me to email support
    I'm hoping they can add the table(s) so I can get this taken care. This was is on e75 and is seeing 0-.5* of spark advance while under load(any load). During decel timing will jump up to normal, but anytime the pedal is pressed it will lock itself back in "Cold start emission red..."
    I added the vertical lines to help show where the mode changes...notice the curve straight down as it entered "cold start emission red..."? the log is full of those curves...only time spark goes up is during decel, even during WOT it was commanding 0*. The curves seem short because I was going over multiple speed bumps at the time.
  12. #152
    Oct 2007
    Crawfordville, FL
    2,412
    Tables are added to this morning's build. Please let us know if this does not correct the issue.
    Regards,
    Eric
    Eric Brooks
    HP Tuners, LLC
  13. #153
    May 2016
    1,134
    Awesome. I'll test it out when I get a chance. Thanks
  14. #154
    Sep 2010
    872
    Regards,
    Eric
    WOOT, tables are there now..look at all those zeros...flashing car in a bit and will take it out for a drive in the next few hours
  15. #155
    Sep 2010
    872
    Quote Originally Posted by Jn2 View Post
    I went ahead and moved my values from the "Drive/Neutral" tables into the "Drive/Neutral Alcohol" tables and the issue is resolved The car no longer locks itself to "Cold Start Retard Red..."
    Anyone having this issue update to the recent build and populate those tables accordingly, mine are set to 50 since commanded spark will always be lower than the maximum allowed(50 in my case)
  16. #156
    May 2015
    17
    This is great news!
  17. #157
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    I'm not seeing these tables and have updated twice recently, have they been added to the export cals for Aus?
  18. #158
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by 4wheelinls1 View Post
    No, this is for Copperhead ECU, US cars.
    Eric Brooks
    HP Tuners, LLC
  19. #159
    Nov 2006
    SouthTexas
    20
    Does anyone have a flex fuel file from a 2018 f150. I am trying to do flex fuel on my 2018 mustang. I have enabled flex fuel switch and have copied some tables from previous ff vehicle and it does switch from e85 to 93 and vice versa but i keep getting 2 codes. p2099 and p2097 post catalyst fuel trim system too rich banks 1 and 2 .
  20. #160
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by z28demon View Post
    There is one in the repository
