Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: Comp 274vvt tune file
    Tuner in Training moparsoldier85's Avatar
    Mar 2018
    41
    Cam phaser disabled? Can I ask why would you want it disabled??
    Mar 2019
    MS
    78
    Specs on the Apache Max [email protected] Intake 226 Exhaust 230 Lobe Lift Intake .336 Exhaust .337
    Specs advertised are 275* Intake duration 554 lift
    Exhaust 281* lift 556
    LSA 112
    Mar 2019
    MS
    78
    Quote Originally Posted by Southwest Speed View Post
    Thanks for chiming in!
    We worked on tuning ours yesterday for a good couple hours prior to attempting any Dyno Tuning. It'll start up with some pedal and idle for a good while on it's own before it starts to idle hunt and eventually swing so high and low that it dies out.
    I've adjusted all the DTCs as I would in normal GM tuning but this one (2015 392 Car) has not responded as I'd expected it to. My goal is to get it to start up and idle with zero assist from the driver or accelerator pedal before putting it on the dyno.
    Called Josh at HHP this morning and talked with him for a bit but they don't use HP Tuners at all. He was great and offered some of his thoughts but there are just a few too many differences in the terms between their SCT/Diablo methods and our HPT tables.
    I'm sure somebody has used HPT to tune the 392 with the 274VVT Camshaft. Be great to compare and see where else I can focus some attention on to get the results we'd like to see.
    Here's where I'm at with it as of today:
    Leaving an ass load on the table...You haven't touched the Cam degrees...I posted mine look at it...Its right at 460 HP with almost as much torque at 3krpm.... 3.5 0-60 and 7.2 1/8th @94 Phase limiter must be installed!
    Mar 2019
    MS
    78
    Quote Originally Posted by moparsoldier85 View Post
    Needs a limiter....It keeps you from mechanically tearing shit up...Now you can lean it out and kill it but the limiter allows 15* of movement and is a safety
    May 2019
    North Carolina
    22
    Hey guys if your still having trouble dialing in a 270 or 274 cam. I have tuned the 270 and 74 vvt with good results. You do need to disable ANN as this will cause the idle to hunt operating within its parameters. If you need a base VE table let me know since the one stock is crazy. For idle its all in the TB air flow model raising the first 3 cells by a lot of you need an example let me know I’ll send you a base file from a good running cammed 6.4 that has only headers and a CAI it’ll get you close. Now the cars will auto drive or throttle hang this is taken care of in the small range tb air flow. Spark gets shifted to put the sweet spot in the lower vacuume area and make the other tables match. Most guys are locking the VVT when doing this cam install. Let me know if it’s locked or limited you need at least one or really bad noises happen as valves hit pistons.
    You will also want to raise the shift points as the power comes in much higher. If you don’t it will feel boggy. If you need these changes I’ll be happy to update your tune file with them just post it up and let me know.
    6.1 based 426 stroker fully forged 11.5:1 compression.,Thitek CNC 6.1 Heads, RLD H5 Camshaft, Edelbrock Victor II intake manifold, Hellcat cnc ported TB, FIC 725 cc/min injectors, Legmaker CAI, UPR catch can, BBE 3in exhaust, 3k stall converter , Paramount Nag1, 1K Hp driveshaft and axels, Wavetrac LSD. 400 shot laughing gas on progressive controller. Fore dual pumps with fc3 controller.
  6. #26
    Aug 2019
    SWFL
    20
    Quote Originally Posted by chriscward71 View Post
    Would love to take a look at your tune file. Trying to dial my 274 in as well as the VE / ETC tables as well. Have an M6 with a limiter installed.
    On a quest to not blow up my car.....
  7. #27
    Oct 2020
    New Mexico Albuquerque
    13
    Comp cam 274 hemi
    Makes sense now that folks can't see my upload. Eh...we'll I'll leave it up for future reference to help those in their quest for knowledge.
    Are there not any 2014 and down 6.4 Cars out there with this 274 VVT Camshaft that have used HPT to calibrate the car? Seems to be a pretty popular stick on these rigs so I'd expect to see alot more coming in the future.
    Thanks Mark for chiming in!
    I am using this cam on a 2010 challenger 392 stroker and I have got it pretty down at this point besides the choppy idle. I can send you the tune but I will need a favor also
  8. #28
    Oct 2020
    13
    I would like some help with mine, I have it doing alright. Have only messed with vvt lock pin and idle and my fans. It?s running decent but I know there is a lot left to do
  9. #29
    Aug 2020
    37
    I opened the file without problems, I am using beta
  10. #30
    I tell Ya bud, that tune is pretty much stock. you need to add fuel to the ve tables, pe tables , timing needs bumped and turn off the NN. I tune complete open loop and no NN. That thing is not going to run with that tune . and complete tune needs fixed .
  11. #31
    Quote Originally Posted by PUNISHMENT392 View Post
    that cam is going to have a choppy idle . that's what ya get with a good cam .
  12. #32
    Oct 2020
    13
    do you still have thatntune ?
  13. #33
    Aug 2021
    6
    I have a 18 srt was a 6.4 car i have a 5.7 hemi 274 comp cam 3"exhust 308 gears shorty factory srt headers installed for now while my new motor is being built I'm new to tuning been trying to fix a idle problem i can get it to run and idle great with this tune for about 30-45 min of drive time then it will slowly start hanging it will idle up from 3mph to 20 once the car starts rolling and will hang around 1200rpm till it gets under 3 mph any help would be appreciated i cant for the life of me figure out this problem i bought a tune off Dave at b&g tune shop and it wont hardly run at all with that tune I know I'm over looking something any help I can would be greatly appreciated
  14. #34
    Tuning Addict
    6,783
    Quote Originally Posted by LilRed1979 View Post
    Try this - Don't forget to dial your VE in...
    ~Greg Huggins~
  15. #35
    Aug 2021
    6
    thank you GHUGGINS that helped tremendously I will work on fine tuning my ve tables now I just tried the tune and did a vcm scan I think it will do good when I get the ve dialed in thank you very much for the help again
  16. #36
    Tuning Addict
    6,783
    No problem
    I didn't do it in that tune, but you might also want to look up a 5.7 11ish truck tune and grab the lower airflow values out of the tb airflow table since the cam shouldn't require or flow anywhere near that much air anymore at idle. This will help your TB model to better control things...
    ~Greg Huggins~
  17. #37
    Aug 2021
    6
    Thanks again ghuggins for the help i will check that out on the truck tb airflow i got the ve dialed in pretty good last night should i tune on the timing any more or do you think its pretty close
  18. #38
    Tuning Addict
    6,783
    If your running 87 you could still add some more in, especially in the lower rpm off idle to full load areas. If your running 93 - well she could take a lot in certain areas and even a decent chunk in wot areas. Just keep in mind timing needs to transition and blend table to table, so try to make some of the same changes to the main 3...
    ~Greg Huggins~
