I need some help. I have tuned the Viper having intake, headers, off road pipes, underdrive pulley.
i keep getting the following codes:
- P0068
- P2106
- P2174
- P2282
and it goes into limp mode. the MAF tables are modified for the added mods. I have not touch the MAP table figures.
I can't look at the file since I'm at work, but you didn't touch any of the throttle tables, correct?
Also, are you using the latest beta software? If so, have you tried disabling all of the diagnostics under the Engine Diagnostics - General tab?
Given the codes, the first thing I'd do is put the stock airbox back on and see if it fixes the issue. Aftermarket intakes on Gen 4 and 5 Vipers are nothing but trouble, and I'm thinking your troubles are all related to that.
