2014 Charger 5.7 Gets stuck in 3rd after HP Tuners flash
After the flash the car will shift 1-2-3 then be stuck in 3rd.. When put in reverse after it get stuck in 3rd there is a delay before reverse is engaged. I've tuned other '14 Chargers without issue, this is obviously a very serious issue. Seems that the car pulls timing before it gets put into this "limp" mode.
Any ideas? Does this with the stock file that was read/reflashed.
stock.hpt
Ended up being the customer had changed gear ratios and flashed it back to stock when it was brought. Any ETA on when we are going to be able to change gear ratios on HPT?
