HPT Employee
2015-2017 Dodge Tuning (Important Information)
Please note the following process that is required to tune your 2015-2017 Dodge/Chrysler/Jeep/RAM (ALL MODELS, except the 2015+ Dodge Viper):
Please use this link for ordering and the most up to date information concerning the service https://www.hptuners.com/product/dodge-pcm-services/
NOTE: If you are sending us a spare PCM, please make sure to send a read from the stock PCM. While we can unlock it as a blank PCM without a read, you would have to flash the correct OS/VIN onto the PCM as well as most likely do a throttle re-learn and/or SKIM re-learn. If you can supply a stock read, we can flash the PCM here. The stock read must be done as a GPEC2A, 2015+ Dodge or a GPEC2, 2015+ Dodge (depending on which PCM the vehicle is equipped with. Please see the Dodge PCM Identification Thread if you are unsure which PCM you have). If you do not have access to perform the read, please download the latest update from your customer page and try again.
After the PCM arrives at HPT, an HP Tuners engineer will modify the PCM and enable your HP Tuners software so that the 2015+ can then be read, licensed, edited, and flashed with HP Tuners software! This is a one-time modification that will not affect other operations of the PCM. The factory tools will still work for service. And HP Tuners will then work for tuning!
NOTE: While there is no hardware modification, the back cover of the PCM does need to be removed.
From there, you may tune the PCM with HP Tuners by licensing the PCM for 2 credits.
Please email Sales if you have any further questions.
Thanks!
