Ok so I have a 2013 gt mustang and decided to give tuning a try on this platform, little bit different beast then my turbo 4's and cobb software. Mods are:
Cobrat jet intake with super cobra jet throttle body and 5" cold air intake
Comp stage 3 cams with stiffer valve springs and limiters only on the exhaust side(per my last tuners request)
1 7/8 headers, no cats and stainless works catback
47lbs injectors
Non-tune related mods:
built bottom end with stock compression
stock gear ratio for now
stock tires till I bolt on the drag setup
So I believe I got a good starting point for the scj throttle body with a cj tune I downloaded from here earlier. I know what I need to set the afr's to on 93 and e85. I found which tables to adjust for the vct but I'm not sure what to do about limiting the cam phasing. My old tuner said he limited my cam phasing to 60* in my tune to be safe because of not having limiters on the intake side and I don't want to have a valve to valve even. So which table do I adjust to limit the phasing to 60*. Also any other stuff I need to be worried about, thank you.
