Results 1 to 6 of 6
Thread: Histogram for WOT SD boost tuning
    Sep 2014
    31
    I have tuned the primary VE table now and it is spot on. Using the histogram with lambda error PID and Primary VE vs RPM vs MAP.
    I use custom 2 bar os only SD no maf, car is a 2005 corvette c6 with supercharger
    i have set my PE table.
    But how do i do it on WOT boost VE table? i tested the histogram lambda error PID and Boost VE but i did only get black squares in the histogram
    Tuning Addict
    6,815
    Here, see if this one works for you. It's set up "I think" currently to datalog fuel trim corrections in the 2 bar VE as to that's what I've been using it for the last few days. All you need to do is copy and paste all of the parameters for datalogging VE. It should be number 3 in the histograms. OR you can use this setup and just enter in your wideband. I think I have one already for wideband on number 4 histogram come to think of it. Having a brain fart right now
    Anyhow these are what I use...
    ~Greg Huggins~
    Sep 2014
    31
    Thank you i will try this tomorrow!
    Sep 2014
    31
    I did find the problem, It was black background in the cells and black text
    Tuning Addict
    6,815
    Did the config work for you? I've had a few other people tell me that it didn't work for them. Was just wondering if it had to do with 2.24 updates or operating versions or something.
    Glad to hear you got your problem sorted out...
    ~Greg Huggins~
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by n_brio View Post
    You can also change the histogram to show areas of boost as well, all on one screen. That way you can see everything at once...
    In histogram settings, go to the histogram you've got VE stuff in, then on the second tab (row & col axis), hit "click to clear" at the top right. Then go down to the "labels" section of the column axis and you can put in whatever you want. I set mine up with these:
    15,21,26,32,38,43,49,54,60,66,71,77,83,88,94,99,10 5,110,114,119,124,128,133,138,143,147,152,157,161, 166,171,175,180,185
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
