2009 Challenger Intermit Stall
2009 Challenger SRT 6.1 Manual- stalls when engaging clutch on decel once out of 10 times. strange .Fuel Trims look great -3. Has Saleen SC .Desired idle speed 816 RPM Hot base idle. Its like I need to increase the dashpot function( GM stuff)slow the throttle return to idle.
Can any share any light on the idle- Torque and Spark, Proportional - Derivative - and Integral tables.???
looked at that tune file one thing i did notice that might be causing your car to stall out in my opinion is the pedal power request table and the expected pedal tables are off if you notice in the little explination box at the bottom of the window those 2 tables must be inverse of each other and those tables from what i saw are fighting each other.. you may wanna give those 2 tables a look at from what i understand they are rpm vs speed so it could be causing you that glitch on decel... good luck brotha
