Shawnsc-12.hpt
Stated in previous post stall once out of 10 cruising push the clutch in and dies. LTFT -3 Idle 900 RPM File attached
Acts like it need a dashpot slow the rpm throttle return Throttle goes to 4% and timing goes negative then stalls> Other than that runs great
570 HP rear wheel driveability good 2 Bar Map
