Results 1 to 2 of 2
Thread: File of Intermittent stall 2009 SC Challenger STR 6.1 manual
    Sep 2006
    Thorntown Indiana
    16
    Shawnsc-12.hpt
    Stated in previous post stall once out of 10 cruising push the clutch in and dies. LTFT -3 Idle 900 RPM File attached
    Acts like it need a dashpot slow the rpm throttle return Throttle goes to 4% and timing goes negative then stalls> Other than that runs great
    570 HP rear wheel driveability good 2 Bar Map
    Nov 2007
    232
    What size injectors? Why isn't the map changed to represent a 2 bar? I see that in the diag the values have been changed, but in another s/c tune I saw that the linear had been changed. I'm new to dodge so these are more just questions for myself than anything else. I did see a lot of the tb tables were changed as well. I know on the GM's and ford's if those aren't right they can play hell with other aspects of the tune. Sorry I'm not much help regarding your issue.
    I'm comparing to a 2013 srt file, so some of that may just be the difference in the engine and year.
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
