Results 1 to 6 of 6
Thread: Ba xr6t
    Aug 2014
    7
    Ba xr6t
    Hey guys,
    Have a BA XR6T auto I have installed id1000's, valve springs and fuel pump. Tuned up fine however when sitting in Park or neutral the fuel trims start climbing till they max out then throws up an P0171 too lean bank 1, P1131 P1132 02 lean and rich errors (I have changed 02 sensor and these 2 haven't come back up), P2105 P2110 throttle actuator control system forced shutdown etc.
    I am going to try another throttle body tomorrow to eliminate it.
    The car drives and boosts perfectly, can sit idling in gear for as long as you want trimming 5% stft but when selecting park or neutral and idling the trim starts climbing to +30's and then throws the error.
    Has anyone had this issue?
    Jez
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    You need to scale the injectors correctly
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Aug 2014
    7
    Quote Originally Posted by JETURBO View Post
    This was my thoughts at first. However it doesn't make sense that idling in gear is trimming stft perfectly and off boost and on boost are exactly as commanded.
    I will recheck my calculations
    Aug 2012
    Melbourne Australia
    344
    Sounds more like you have the Offset wrong (too small). Are these the numbers you had:
    http://www.hptuners.com/forum/showth...l=1#post360766
    Sep 2013
    Sydney
    123
    Voltage drop due to rpm drop or similar? Possible Incorrect voltage offset?
    I thought you tuned with sct Jez
    Tuner Stevo's Avatar
    Mar 2011
    Melbourne
    86
    Quote Originally Posted by DVS JEZ View Post
    How did you end up going Jez?
