Whenever I check for engine codes on any vehicle I get this popup box and then the program closes. Anyone else having this issue?
AAHHHHH!!!!!!
Yes... Since the Firmware Update.
http://www.hptuners.com/forum/showth...l=1#post379514
I already reported the Error weeks ago...
What vehicles is this happening on?
We got this guy Not Sure, ...
Vauxhall Astra 2.0 (VXR SIDI Turbo)
What controller is in the vehicle?
happened on my 2010 Camaro E38 last week on 2.24... haven't tried the newest versions... I also have been getting random "Service Stabilitrak" message that goes away upon startup...
2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
ZL1 Wheels/Tires
Also saw this same crash on a 2014 Silverado using 2.24.1127 when I tried to pull up the dtcs. Truck had a map code thrown and I was able to see it before it crashed. Pulled up a 2nd time fine.
Astra has a E39A ECM
Im having the same problem too. Just got my pro package last week and can't even use the scanner after update. It's frustrating. Im having to wait between e-mail for a fix. Just sent a screen shot and info log to tech support.
Chevy Silverado (V6) 2014, E92 T43
For what it's worth, I just received a e-mail from tech support. Close all programs go to my documents/hptuners/settings/clear everything in the settings folder. Restart the vcm scanner, enter your info and try to connect. It didn't work for me, still getting the error message when reading the DTC's. But it was worth a shot. Hope it helps.
Any news?
I think this will be fixed in Mondays build. Please test and report.
Hi Keith, it works great for me!
Thank you very much
