i feel a dumb asking this but just did a cam swap and a 411 pcm swap to a 98 bird and has a 02 camaro/firebird (156) file. Car has stock 98 engine, 806 heads,ls1 (egr)intake, 1 3/4s headers ory and now the mentioned cam above is a 231/234
my question is what VE and Timing tables to use as a base to start tuning ? do i benefit from the 98 timing that seems a lot more aggressive than other years using this bumpstick? or ill better stick to the safer 02 table. also ve shape is totally different in the 98-00 than the 01-02 bigger ls6 intake equipped cars... is it just the intake that changes everything? i think year after year calibrators fix and upgrade some things and being a ls1 intake car i can stick with a '00 file numbers. what do you think ?
