Results 1 to 5 of 5
Thread: LM2 Scanner Settings
    Tuning Addict
    Jan 2015
    6,822
    Just wondering what everyone was using for their LM2 scanner setups. I've personally tried a few different volts/settings and none seem to be able to get it to read correctly +- 2 of stoichio. I've even tried a few different widebands already in HP's scanner and none work just right. They always read further out the richer it gets vs what's displayed on the control head. Do I need to change some of the internal analog output settings to get it to work right? I've already got the analog output taking data slower to make it read withen 2% of fuel trims.
    Any and all input greatly appreciated.
    Thanks,
    Greg
    ~Greg Huggins~
    Jun 2013
    NC
    29
    Sounds like the Analog Output in the LM2 isn't programmed to output 0-5v. I'm assuming you've gone into the LM2 and ensured that you've got the correct AFR to V table setup for your output? If that's correct, and you're still having variances then you'll have to adjust the ground offset.
    I just had to reprogram my LM1 for the 0-5v output from the controller, as I was having the same issue you are seeing, once I fixed the output my afrs logged and displayed were spot on.
    Tuning Addict
    Jan 2015
    6,822
    Just double checked. It's set to afr on output 1 and 0v=7.35 and 5v=22.39. What are you entering into the hptuner scanner settings? OR are you entering in different voltage settings in the tool itself, because I have read where people are changing it to 10min afr and 22max afr to get them to display accurately, but this seems to defeat the purpose in some aspects.
    ~Greg Huggins~
    Jun 2013
    NC
    29
    I've got 0v=10-5v=20afr in the LM1, and then created the LM1 pid with (volts/.5)+10 so I could change the ground offset if I needed, but never had to.
    Since you're rarely going to operate on the fringe of 10&20afr, it seems wasteful to have the output extend from the default 0v=7.35-5v=22.39afr since you're just using up resolution for areas you'll never run at, imo.
    I actually just purchased an LM2 dual today, and will have that setup this weekend. If you still are having issues I should have more insight once the LM2 is hooked up.
    Tuning Addict
    Jan 2015
    6,822
    Ok so 10 at 0 then 20 at 5 and use .5 + 10. The next one I have it on, I'll try that and see how it goes.
