Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 83
Thread: Off Board Programming 2010+ E38 with SPS
  1. #41
    Jan 2009
    Spokane, WA
    480
    Quote Originally Posted by hefe33 View Post
    the weird part for me was that HPT worked fine with my home-made adapter, but not GM stuff...
    Only guess I have is you were missing a ground or etc?
  2. #42
    Jun 2012
    30
    that would be my guess too...
    too much resistance thru one of my wires... maybe HPT is less picky.. who knows..
    glad it's over!
    hope the OP is all set too, didn't mean for my post to take over his thread!
  3. #43
    Tuner ryanvv355's Avatar
    Dec 2008
    Hudsonville, MI
    99
    I still cannot get 2010+ ECM's to take a cal over my benchtop setup, mongoose and SPS. I need to try it with a BCM.
    1971 Olds Cutlass Supreme
    6.0/4L80E;
    Single turbo - Gen 3 controls, HPT 2bar OS
    2014 Sierra Denali
    L86 6.2/6L80E; HPT e85
    2005 Chevy Colorado
    LH6 5.3/M5 swap; Cone Killa
  4. #44
    Dec 2008
    Hudsonville, MI
    99
    Tried adding a BCM tonight, still did not work, in fact I could not program the BCM either. Going to try an MDI tomorrow. Maybe someone with a working system can post up what wires are being used in your benchtop system to get this to work?
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  5. #45
    Jun 2012
    30
    What error do you get?
  6. #46
    Jan 2009
    Spokane, WA
    480
    Something not right. I do lots of them with no issues, with a MDI on the bench. If you have access to SPS, then you have access to wiring diagrams. ...Start there
  7. #47
    Quote Originally Posted by ryanvv355 View Post
    Curious to how you wired in the BCM.
  8. #48
    Dec 2008
    Hudsonville, MI
    99
    I have a BCM from a 2007.5 Silverado. This p/n interchanges up to 2011. I have it wired as such:
    C1 P2 ignition 12v
    C3 P3 12v batt
    C3 P5 ground
    C3 P8 CAN +
    C3 P 9 CAN -
    I have 60 ohms across my CAN bus with the BCM and ECM connected
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  9. #49
    Dec 2008
    Hudsonville, MI
    99
    Ok the madness continues!! I now have a BCM, ECM and instrument cluster all hooked up, high speed LAN, and low speed still not working with the Mongoose! Going to try an MDI tomorrow.
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  10. #50
    Jun 2012
    30
    man... if you feel like driving to Saginaw, you can use my benchtop setup..
    once I bought the eficonnection pro benchtop setup, all my weird problems went away
    https://www.eficonnection.com/eficon...ogramming.aspx
    it made no sense, all the wires were the same.. but it all works now so I quit trying to figure it out
    FWIW, I use a Mongoose and SPS too
  11. #51
    I have their EFI pro series, and cannot standalone program with my Bosch M-VCI.
  12. #52
    Dec 2008
    Hudsonville, MI
    99
    MDI usage did not work out. The tech I know with one was reluctant to let me try it with his PC and I did not have the proper drivers for it. I now have added a TCM to the mix and it still doesn't work.
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  13. #53
    Dec 2008
    Hudsonville, MI
    99
    A question to ask is aside from Dsteck, how long ago did you guys have success? From the probes I have put out into the industry this a recent thing within the last 10 months.
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  14. #54
    Programmed an E67 with 2011 VIN today stand alone. No issues with MDI and SPS.
    As for BCM programming, the BCM I used did need the Communication Enable Relay Control wire attached to allow the BCM to take a program.
    In your BCM wiring look at Pin #19 on the X3 connector. I think you have the same BCM I use at times.
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
  15. #55
    Dec 2008
    Hudsonville, MI
    99
    Radrace, how do you hook up the comm enable wire? 12v?
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  16. #56
    yes 12v
  17. #57
    Dec 2008
    Hudsonville, MI
    99
    Ok I now can get past the off board programming prompt, but need to enter a security code to change the cal. Any ideas?
    I installed a Ign 12v on the comm enable, connected the serial wake up wire from E38 to BCM, and installed a ground at J4 P9 on the BCM.
    6.0/4L80E;
    2014 Sierra Denali
    2005 Chevy Colorado
  18. #58
    I've only had the security code prompt come up once when trying to program an E38 ECM that had already been programmed with a Global-A platform calibration.
    I've never had that prompt when programming any other new E38, E67, BCM, or TeCHM
  19. #59
    Dec 2008
    Hudsonville, MI
    99
    I got the security prompt when trying to turn a truck ECM into a Camaro. I did not get the security prompt when going truck VIN to Express van VIN. My goal here was to make a Camaro ECM. I did a write entire of a 12 Camaro with HPT, which changed the VIN, then SPS allowed me to write the Camaro file to the ECM. All is good now.
    Thanks for the help guys.
  20. #60
    May 2017
    6
    Hey guys, ive been searching all over but cannot find a solution and customer service has yet to reply to my email so here i go. I have a swapped 240 that i used hp to tune out vats. Engine and ecm are from g8 l76. Unfortunately i couldnt get speedo reading due to it being an auto car which uses the tcm. So i used gm tis or sps to use a factory ecm calibration from a gxp . It worked except now i cant rear or write using editor even when i try to use previous vin. Most likely due to an updated calibration even with the previous ecm. So how can i unlock it so i can use vats patch?
